ThosL Posted April 6, 2015 Share Posted April 6, 2015 My driver's seat springs have collapsed, support is negligible. So I'm thinking of switching the seats, passenger to driver's side. Is this an easy job? How often is this done? I see two bolts holding in the seats. Quote Link to comment Share on other sites More sharing options...
Rooster2 Posted April 6, 2015 Share Posted April 6, 2015 No, they are not interchangeable. The seat belt buckle would be on the wrong side, and I don't think the bolt hole pattern is the same. In the past I have gone to a wrecking yard, bought a passenger seat, and switched the padding to the driver's seat. That is not difficult to do. There really isn't much in the way of springs to deteriorate. It is the foam padding that breaks down. I use cable ties to secure the seat, instead of the hog rings used by the factor. Quote Link to comment Share on other sites More sharing options...
ccrinc Posted April 6, 2015 Share Posted April 6, 2015 There are 4 bolts (at least) holding the the seats. Quote Link to comment Share on other sites More sharing options...
ThosL Posted April 8, 2015 Author Share Posted April 8, 2015 Thanks for the feedback; I guess I'll have to hold the job until I talk to the guy I know with the Subaru junkyard. Quote Link to comment Share on other sites More sharing options...
wtdash Posted April 11, 2015 Share Posted April 11, 2015 As noted, drivers and passenger are not interchangeable.... Post your YEAR and we can suggest replacements. But ANY Legacy model (L, LS, LSi, GT, OB) from '90-99 will bolt up to a '96-'99 Legacy OB. Also, Impreza and Forester 'thru 2007/8 will work in '90-'99 Legacy OB, but the seat sits higher...esp. the passenger. Swap your buckles to the 'new' seats. I 'think' you can also use the '00-'05 Legacy/Outback in the '90-'99 Legacy, but haven't confirmed that. I know the '05+ Legacy/Outback models won't fit '90-'99. GL Quote Link to comment Share on other sites More sharing options...
