Jabbott126 Posted April 6, 2015 Share Posted April 6, 2015 ok So I have a 90 Loyale turbo and the distributor needs to be replaced. Just wondering if the turbo dizzy is the same as the N/A dizzy. if so im in luck...if not im out $200 bucks Link to comment Share on other sites More sharing options...
rdweninger Posted April 6, 2015 Share Posted April 6, 2015 I had Philbin in Portland OR rebuild mine. Was like $120... new bushings, ign module, vaccum. I shipped via U.S. Mail on Tuesday. I got it back on Friday. You can google them for more info. Link to comment Share on other sites More sharing options...
jono Posted April 6, 2015 Share Posted April 6, 2015 1990 USDM you might be lucky swappping between NA mpfi - did you even get NA mpfi ?, check the part numbers in the casting of the dist body for exact comparison. Not including spfi dist, we got about four or five different distributors over the EA82 range. You'd also be comparing look and wire count, colours and pin arrangement Link to comment Share on other sites More sharing options...
Gloyale Posted April 8, 2015 Share Posted April 8, 2015 All optical dizziness spfi and mpfi turbo or non are the same from 88-94 87 also are the same guts but different connector Link to comment Share on other sites More sharing options...
Jabbott126 Posted April 9, 2015 Author Share Posted April 9, 2015 thanks for the input guys. Should help me locate one quickly. Link to comment Share on other sites More sharing options...
