I don't know what the story is on this car, but if it has a decent body and motor it's really not worth giving up on.  Around here a 97 Legacy is worth $2k with problems, more if it runs well and doesn't have problems.  Don't know about where your at.
Dash lights are all done by the illumination control module which is known to burn out. Especially if someone put an aftermarket radio in it and hooked up the dimmer wire.
Dome light is usually pretty easy to figure out. It either has power or it doesn't. A test light at the bulb will tell you that. If the Door indicator in the cluster works when a door is open, the fuses are good and the problem is just with the dome light or the wiring to it.
Hi beams stuck on, and the signals don't work, could be damaged signal switch in the column. Are there a bunch of splices under the dash? Does it look like there was an aftermarket alarm module installed or anything like that?
