Exhaust manifold cast piece? Need help
If you don't have any of the exhaust recirculation stuff or if you want to delete them have the exhaust flanges made to just bolt to the heads. The turbo headers just bolt to the heads and the y-pipes do on the non catalyst cars.
So taking those off and taking and blocking off the egr would suffice? Or could I just remove these
Wy not just leave them in? On mine, i removed the threaded pipe from the spacer, then cut them to just 2" long, heated the end, hammered the end flat, and welded them shut, and reinstalled into the spacer. Now the spacer is just acting as an adapter between the pipe and the head.
Because my spacer is ruined, po welded the exhaust right to it.
