April 12, 201511 yr i figured sometimes it is cheaper in the long run to buy new parts unless it is a 300 dollar relay but brakes and suspention should always be new for your piece of mind. if you don't get a piece then you mind and if you wreck your car because of a cheap used part then it gets expencive. my father tried to make hold down pins for his 98 subaru instead if buying a hard parts kit and we almost kissed a rock wall but we got stopped by down shifting to first gear we then had to redo the whole brake system again.
