nipper Posted April 12, 2015 Share Posted April 12, 2015 2005 Outback. Imagine my chagrin, and annoyance when I discovered my tailgate does not lock. I have no idea how long this has been going on, what between Moms health issues and mines, possibly many months. The tailgate will close and the latch works. The tailgate does not lock. You operate the locks from the fob and you hear or feel nothing. Open the hatch the alarm goes off. I havent see n this posted here before, so is this adjustable, rebuildable, or do i need an entire new latch. I will have to say that NYC has gotten much safer, as my best bet is that this has been going on for maybe 5 months and no one has ever broke into the car while its parked. Link to comment Share on other sites More sharing options...
lstevens76 Posted April 12, 2015 Share Posted April 12, 2015 Does it have a keyhole on the back? If so try doing that. My '96 Impreza OBS won't unlock from the power locks nor the key so I can feel your pain, even though it's the opposite. Not locking can be just as frustrating as not being able to open it. lol Link to comment Share on other sites More sharing options...
nipper Posted April 12, 2015 Author Share Posted April 12, 2015 Nope no Keyhole (I just double checked) Link to comment Share on other sites More sharing options...
lstevens76 Posted April 12, 2015 Share Posted April 12, 2015 It sounds like the lock actuator is bad. I would pull the lower trim pieces off the hatch and see if you can manually lock it. This would at least give you some piece of mind. If the Lock Actuator is not working once you have the hatch trim off you can monitor it and hear it directly. If it doesn't appear to be working unplug it and through a multimeter on it (or even a test light) and see if when you click the fob if it actually gets power. If it does then your actuator is probably dead. Link to comment Share on other sites More sharing options...
montana tom Posted April 12, 2015 Share Posted April 12, 2015 (edited) This sounds similar to an issue I had with the rear latch on a 2008 obw. On the inside is there a small (3x2) plastic cover that could be pried off? If so ,pop it off, shine a light inside , look for a long white plastic arm on the right (drivers) side. flip it either up to horizontal or down and see if your hatch locks. Look for my post (on page 3) on 2008 obw rear hatch to see pictures and hear the saga . Edited April 12, 2015 by montana tom Link to comment Share on other sites More sharing options...
wirelessenabled Posted April 12, 2015 Share Posted April 12, 2015 (edited) My 2000 OBW had a similar problem of not locking. In my case you could hear the actuator thunking when you pressed the remote. It is a simple matter to remove the inside trim on the tailgate to access the lock and actuator. My actuator was working but the plastic piece that attached the actuator arm to the locking mechanism had broken. Being the pack rat I am I still have the actuator part #60319FA201. It does not look like it is easily rebuildable. Looks like that part number only fits up through 2004. Wow $75 at online dealers. I lucked out and got a new one on Ebay for $15 or so I my memory is correct, Edited April 12, 2015 by wirelessenabled Link to comment Share on other sites More sharing options...
nipper Posted April 13, 2015 Author Share Posted April 13, 2015 On the 2005, does the entire trim peice in the tailgate come off as one part? Link to comment Share on other sites More sharing options...
nipper Posted April 13, 2015 Author Share Posted April 13, 2015 Never mind,wll ill be darned And i looked and found the same broken wire. Link to comment Share on other sites More sharing options...
nipper Posted April 13, 2015 Author Share Posted April 13, 2015 Link to comment Share on other sites More sharing options...
nipper Posted April 13, 2015 Author Share Posted April 13, 2015 (edited) Before I attack this, anyone have a wire supplier? Im thinking fo going same gauge multi strand so the wre would allow more flexing. To me this is inexcusable. Edited April 13, 2015 by nipper Link to comment Share on other sites More sharing options...
nipper Posted April 14, 2015 Author Share Posted April 14, 2015 Going to start a new thread. Link to comment Share on other sites More sharing options...
