1000 Pistes Posted April 14, 2015 Share Posted April 14, 2015 (edited) First of all I would like to know if exists some FWD D/R 5 or 4 speed gearbox. Second,if it is possible to transform some 5speed D/R AWD gearbox to be used as FWD with EA71 fat case. Third,all the needed parts to fit some D/R 5speed gearbox to the EA71 fat case. Fourth,all the gear ratios,FDs,the transfer ratios of all the D/R 5speeds for EA71 engine. Edited May 20, 2015 by 1000 Pistes Quote Link to comment Share on other sites More sharing options...
jmoss5723 Posted April 15, 2015 Share Posted April 15, 2015 This seems like a tall order. Quote Link to comment Share on other sites More sharing options...
Leeroy Posted April 16, 2015 Share Posted April 16, 2015 Yes very tall! Especially considering no FWD dual range transmission exists! To the OP, the only Subaru transmissions that are dual range are either 4WD or AWD. While anything is possible, running a 4WD/AWD transmission permanently in FWD would mean you have to plug the transmission output shaft (basically so the oil stays in the transmission!) and while it has been done by people as a 'stop gap', not sure it would work long term. 1 Quote Link to comment Share on other sites More sharing options...
1000 Pistes Posted April 16, 2015 Author Share Posted April 16, 2015 Where I could find the gear ratios,final drives,transfer ratios of all the EA & EJ D/R gearboxes????? I would like to know,also,the part number-code of the EA71 fat case bellhousing(side starter). Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted April 16, 2015 Share Posted April 16, 2015 Where I could find the gear ratios, final drives, transfer ratios of all the EA & EJ D/R gearboxes????? Here: ~► http://www.gearhack.com/myink/ViewPage.php?file=docs/Subaru+Transmission+Chart ~► http://members.iinet.net.au/~wearne/Subaru%20Transmissions%20Specs.pdf Kind Regards. Quote Link to comment Share on other sites More sharing options...
1000 Pistes Posted April 16, 2015 Author Share Posted April 16, 2015 Thank you Loyale 2.7 Tubo for the chart. They are for the single range EJ gearboxes. I am looking,also, for the gear chart concerning the D/R EA and EJ gearboxes. Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted April 16, 2015 Share Posted April 16, 2015 (edited) ~► http://www.ultimatesubaru.org/forum/topic/81963-ea8182-mt-gear-ratios/ ~► http://www.dirtyimpreza.com/forums/showthread.php?2728-EA-manual-transmission-specifications Edited April 16, 2015 by Loyale 2.7 Turbo Quote Link to comment Share on other sites More sharing options...
1000 Pistes Posted April 16, 2015 Author Share Posted April 16, 2015 ~► http://www.ultimatesubaru.org/forum/topic/81963-ea8182-mt-gear-ratios/ Thank you, Fast reply. Chart for the EJ D/R ???? Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted April 16, 2015 Share Posted April 16, 2015 ...Chart for the EJ D/R ???? ~► http://www.northursalia.com/techdocs/trannychart/trannychart.pdf ~► http://members.iinet.net.au/~wearne/Subaru%20Transmissions%20Specs.pdf ~► http://www.gearhack.com/myink/ViewPage.php?file=docs/Subaru%20Transmission%20Chart Kind Regards. Quote Link to comment Share on other sites More sharing options...
1000 Pistes Posted April 16, 2015 Author Share Posted April 16, 2015 I can't see the EJ D/R chart. Quote Link to comment Share on other sites More sharing options...
1000 Pistes Posted April 17, 2015 Author Share Posted April 17, 2015 ??? Quote Link to comment Share on other sites More sharing options...
1000 Pistes Posted April 21, 2015 Author Share Posted April 21, 2015 the EJ D/R chart ??? Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted April 21, 2015 Share Posted April 21, 2015 What happens when you do a Click on the Link to the .pdf Files? Maybe your computer does Not have a PDF reader installed... Kind Regards. Quote Link to comment Share on other sites More sharing options...
1000 Pistes Posted April 21, 2015 Author Share Posted April 21, 2015 now it's ok. the low range ratio of the EJ gearboxes is where it mentioned 1.1 ??? only these are dual range EJ gearboxes??? Quote Link to comment Share on other sites More sharing options...
comatosellama Posted April 22, 2015 Share Posted April 22, 2015 Jezek, do you have like a separate hard drive for your limitless supply of subaru links? Lol 2 Quote Link to comment Share on other sites More sharing options...
1000 Pistes Posted April 24, 2015 Author Share Posted April 24, 2015 thank you Loyale 2.7 Turbo .... finaly: is it possible to transform some 5speed D/R AWD gearbox to be used as FWD to fit on some EA71 fat case? Quote Link to comment Share on other sites More sharing options...
comatosellama Posted April 25, 2015 Share Posted April 25, 2015 thank you Loyale 2.7 Turbo .... finaly: is it possible to transform some 5speed D/R AWD gearbox to be used as FWD to fit on some EA71 fat case? You could just get an 4wd, get a stub balanced, and just run that. Tunnel issues might happen though, I dunno Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted April 25, 2015 Share Posted April 25, 2015 thank you Loyale 2.7 Turbo .... finaly: is it possible to transform some 5speed D/R AWD gearbox to be used as FWD to fit on some EA71 fat case? You're Welcome. Have you considered the posibility of making your Subie to be 4WD? Even if it doesn't have the tunnel for the Transmission's shaft, it could be done. Subaru made Few FF-1 wagons in 4WD, with the 1.3L (1300) engine. I've seen full 4WD Drivetrain & Engine swaps from Subarus to another cars... ~► http://www.ultimatesubaru.org/forum/topic/50983-strange-and-weird-subaru-stuff/page-83?do=findComment&comment=1280045 Kind Regards. Quote Link to comment Share on other sites More sharing options...
1000 Pistes Posted April 25, 2015 Author Share Posted April 25, 2015 (edited) You're Welcome. Have you considered the posibility of making your Subie to be 4WD? Even if it doesn't have the tunnel for the Transmission's shaft, it could be done. Subaru made Few FF-1 wagons in 4WD, with the 1.3L (1300) engine. I've seen full 4WD Drivetrain & Engine swaps from Subarus to another cars... ~► http://www.ultimatesubaru.org/forum/topic/50983-strange-and-weird-subaru-stuff/page-83?do=findComment&comment=1280045 Kind Regards. My target is not to turn my car to 4WD. My target is to prepare my 1973 4door Sedan as gravel rally car of the time(1.6 FWD),accordingly to F.I.A. rules of the era. It must use the EA71 engine and I am willing to put some 4WD D/R 5speed gearbox transformed to FWD(cutting-plugging the rear end)and using some front LSD(helical)differential. I am trying to know if it is possible to turn some 4WD D/R 5speed gearbox to FWD D/R 5speed one with front helical LSD . This way I could having 10 speed gearbox. To be noted that I have not knowledge of these transmission systems as they wasn't largely shown in my country(Greece). Edited April 25, 2015 by 1000 Pistes 1 Quote Link to comment Share on other sites More sharing options...
1000 Pistes Posted April 28, 2015 Author Share Posted April 28, 2015 Any alloy adaptor to joint the EA71(fat case)engine to the EJ gearbox? Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted April 28, 2015 Share Posted April 28, 2015 Sounds like you'll need a Custom Build one. You might Ask directly for such thing to the Great Fabricators that are here, in USMB, there are some, all of them are great. Kind Regards. Quote Link to comment Share on other sites More sharing options...
1000 Pistes Posted April 28, 2015 Author Share Posted April 28, 2015 Sounds like you'll need a Custom Build one. You might Ask directly for such thing to the Great Fabricators that are here, in USMB, there are some, all of them are great. Kind Regards. thank you.... Quote Link to comment Share on other sites More sharing options...
