soopsoop Posted April 14, 2015 Share Posted April 14, 2015 where is the neutral safty switch on a 88 dl wagon? Link to comment Share on other sites More sharing options...
nipper Posted April 15, 2015 Share Posted April 15, 2015 Manual? Link to comment Share on other sites More sharing options...
wagonist Posted April 15, 2015 Share Posted April 15, 2015 on the gearstick. If you remove the centre console, there will be a bunch of wires hanging off the base of the shifter. The safety switch is the one which joins the 2 thickest wires (usually BW & BY) Link to comment Share on other sites More sharing options...
soopsoop Posted April 15, 2015 Author Share Posted April 15, 2015 its a manual Link to comment Share on other sites More sharing options...
wagonist Posted April 16, 2015 Share Posted April 16, 2015 Manuals have a neutral safety switch in the US? I know later gearboxes have a neutral switch on the trans. I think its on the left side behind the reverse light switch. Link to comment Share on other sites More sharing options...
Gloyale Posted April 17, 2015 Share Posted April 17, 2015 Manual trans do not have a Nuetral "safety" switch. There is a switch, on ether left side of trans, that tells the ECU when the car is in a gear, or in Nuetral. However this has nothing to do with starting the car and is not a "safety" feature. It is merely to help the ECU control idle and fuel cut during off throttle coasting. Link to comment Share on other sites More sharing options...
soopsoop Posted April 23, 2015 Author Share Posted April 23, 2015 ah that makes sense,is that why i can start my car in gear? is there a switch on the clutch? Link to comment Share on other sites More sharing options...
nipper Posted April 23, 2015 Share Posted April 23, 2015 Well lets not be so pickey about names An automatic in a subaru has an "inhibitor" switch. This tells the car what gear it is in Manuals will have a clutch switch of some kind, and sometimes a neutral safety switch on the transmission. More modern manuals may even have some sort of switches to tell the computer what gear you selected. Someone may have bypassed your clutch switch. Not uncommon. Link to comment Share on other sites More sharing options...
