ninerashbourne Posted April 16, 2015 Share Posted April 16, 2015 (edited) Hello Everyone, I have a 2005 Outback LL Bean and the problem I'm having is my rear hatch door cannot be locked or unlocked from the Fob or on board controls. I took the rear panel off and was able to access the actuator which I took out. Applying 12vdc to it the actuator did not function. Can anyone tell me where I can find a new one. Have searched and can only find actuators for passenger doors. Thank you Edited April 16, 2015 by ninerashbourne Link to comment Share on other sites More sharing options...
nipper Posted April 16, 2015 Share Posted April 16, 2015 (edited) I ahte to be the bearer of bad news, but on the plus side how is your splicing skills? (look in the right side accordion boot at the hatch) Thats how i found this http://www.ultimatesubaru.org/forum/topic/153009-broken-wires-in-liftgate/?do=findComment&comment=1281190 Edited April 16, 2015 by nipper 1 Link to comment Share on other sites More sharing options...
montana tom Posted April 16, 2015 Share Posted April 16, 2015 If you applied power and your actuator did not work ,then it may not be the wires as suggested ... Currently on page 4 see my post on 2008 obw hatch not working and see the picture and part # of factory part that you may need. 1 Link to comment Share on other sites More sharing options...
ninerashbourne Posted April 16, 2015 Author Share Posted April 16, 2015 I ahte to be the bearer of bad news, but on the plus side how is your splicing skills? (look in the right side accordion boot at the hatch) Thats how i found this http://www.ultimatesubaru.org/forum/topic/153009-broken-wires-in-liftgate/?do=findComment&comment=1281190 I knew I also had a wiring issue that I did not post yesterday and I wasn't looking forward to hunting it down.I was getting voltage when I hit the unlock on the Fob but nothing on the lock side. Just as you said I found the problem in the Accordion boot on the right side. So using some additional 18Awg and some butt splices I was able to repair the cabling. Finally I took apart the actuator and freed up the wheel mechanism, used some super glue and scotch tape and reinstalled the unit. Amazingly she is working again. Thanks nipper for the tech support. Link to comment Share on other sites More sharing options...
ninerashbourne Posted April 17, 2015 Author Share Posted April 17, 2015 If you applied power and your actuator did not work ,then it may not be the wires as suggested ... Currently on page 4 see my post on 2008 obw hatch not working and see the picture and part # of factory part that you may need. Thank you for your reply. I had a wiring issue that I did not post before but I found that and repaired it. I decided to take apart the actuator and I managed to free up the main wheel and verified that the dc motor was good by applying 12vdc. Using some super glue and scotch tape I put the actuator back together and reinstalled the unit and it's working. Thanks again for your post, if the unit locks up again I will use your info to order a new one. Link to comment Share on other sites More sharing options...
nipper Posted April 17, 2015 Share Posted April 17, 2015 I knew I also had a wiring issue that I did not post yesterday and I wasn't looking forward to hunting it down.I was getting voltage when I hit the unlock on the Fob but nothing on the lock side. Just as you said I found the problem in the Accordion boot on the right side. So using some additional 18Awg and some butt splices I was able to repair the cabling. Finally I took apart the actuator and freed up the wheel mechanism, used some super glue and scotch tape and reinstalled the unit. Amazingly she is working again. Thanks nipper for the tech support. hehe want to come over and do mine. i am so grounded from sinuses issues. Glad its fixed. Link to comment Share on other sites More sharing options...
