dwwataz Posted April 17, 2015 Share Posted April 17, 2015 OK, so I got BC stage 2 AVCS cams for my V7 EJ207 and after installing my timing belt I'm interfering. If I leave my driver's side exhaust cam out of alignment, the crank will spin freely all day. As soon as I line it up.. it interferes. I've tried going 180 out, I've tried going 190484645 out and it always comes to a stop at the same exact spot. I'm stumped. I was a Honda tech prior to messing up my back in an accident and I now do HVAC, so I'm very mechanically inclined. This is my second Subaru and second TB job on this car alone. Link to comment Share on other sites More sharing options...
Fairtax4me Posted April 17, 2015 Share Posted April 17, 2015 Two crank marks, make sure you use the one on the BACK of the sprocket where the reluctor teeth are. Use the notch marks on the cams, not the arrows. 1 Link to comment Share on other sites More sharing options...
dwwataz Posted April 17, 2015 Author Share Posted April 17, 2015 Timing was spot on. Single mark up top on Intake cams and double marks pointed down towards exhaust cams( ex pointed up). Crank was aligned perfectly as well. Link to comment Share on other sites More sharing options...
Fairtax4me Posted April 17, 2015 Share Posted April 17, 2015 If you've double checked to make sure nothing is hitting the flywheel/flexplate (something you might have used to lock the crank for removing the front bolt), either the timing is wrong, or the cams are switched; Intake on exhaust side and vice versa. 1 Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted April 17, 2015 Share Posted April 17, 2015 (edited) On 4/17/2015 at 2:17 AM, dwwataz said: Timing was spot on. Single mark up top on Intake cams and double marks pointed down towards exhaust cams( ex pointed up). Crank was aligned perfectly as well. this will probably be annoying but, 'just to be clear' you shold NOT use the triangle/arrow on the front of the crank sprocket. Only use the dash on the tab at the back of that sprocket (arrow will at about 3 O'clock position) do a tooth count Edited April 17, 2015 by 1 Lucky Texan Link to comment Share on other sites More sharing options...
