subaru forever Posted April 18, 2015 Share Posted April 18, 2015 I have asked this before.checked everything.relays.4way thing in dash.all fuses.lights work.brake lits.tail lights.no dome lite or blinkers.where can i tap into to reg up the blinkers Link to comment Share on other sites More sharing options...
nipper Posted April 20, 2015 Share Posted April 20, 2015 Im not sure what your asking? Link to comment Share on other sites More sharing options...
subaru forever Posted April 25, 2015 Author Share Posted April 25, 2015 Is there way to by pass the bad switch.in the steering colium.the blinkers or 4 ways do not work Link to comment Share on other sites More sharing options...
nipper Posted April 25, 2015 Share Posted April 25, 2015 How odd, are all the fuses good? Link to comment Share on other sites More sharing options...
subaru forever Posted April 26, 2015 Author Share Posted April 26, 2015 Yes and relays.lights tail lights good.brake lights Link to comment Share on other sites More sharing options...
nipper Posted April 26, 2015 Share Posted April 26, 2015 The two sets of circuits have different feeds. This sounds interesting. Have you checked all the bulbs to see if the filaments are all good? Link to comment Share on other sites More sharing options...
subaru forever Posted April 26, 2015 Author Share Posted April 26, 2015 Yes Link to comment Share on other sites More sharing options...
nipper Posted April 26, 2015 Share Posted April 26, 2015 Your going to make me read a manual arent you Give me a few minutes, i have to find it. Link to comment Share on other sites More sharing options...
subaru forever Posted April 26, 2015 Author Share Posted April 26, 2015 Checked 4way has power but does not work Link to comment Share on other sites More sharing options...
nipper Posted April 26, 2015 Share Posted April 26, 2015 Link to comment Share on other sites More sharing options...
nipper Posted April 26, 2015 Share Posted April 26, 2015 Have you really checked the blinker module? They doont work the way you may be used to. And I was wrong they do overlap. Link to comment Share on other sites More sharing options...
subaru forever Posted April 26, 2015 Author Share Posted April 26, 2015 I have replaced the 3 relays above fuse box.where is it located Link to comment Share on other sites More sharing options...
nipper Posted April 26, 2015 Share Posted April 26, 2015 You cant just replace things blindly, it is time to get the meter out and see whats going on. If you dont have power where it needs to be nothing will work, no solution will work Link to comment Share on other sites More sharing options...
subaru forever Posted April 26, 2015 Author Share Posted April 26, 2015 Yes.but they could have been bad.no harm finding this out Link to comment Share on other sites More sharing options...
nipper Posted April 26, 2015 Share Posted April 26, 2015 (edited) B32 is your turn signal flasher. Edited April 26, 2015 by nipper Link to comment Share on other sites More sharing options...
nipper Posted April 26, 2015 Share Posted April 26, 2015 I think thats it, otherwise i have to scan a page from the manual and i feel lazy Link to comment Share on other sites More sharing options...
nipper Posted April 26, 2015 Share Posted April 26, 2015 http://opposedforces.com/parts/legacy/us_b11/type_45/electronic/electrical_parts_body/illustration_1/ hope that helps Link to comment Share on other sites More sharing options...
subaru forever Posted April 26, 2015 Author Share Posted April 26, 2015 Thanks will check out tomorrow.this will help Link to comment Share on other sites More sharing options...
subaru forever Posted April 26, 2015 Author Share Posted April 26, 2015 Is it square with 3 prungs? Link to comment Share on other sites More sharing options...
subaru forever Posted April 26, 2015 Author Share Posted April 26, 2015 Under the dash behind 4way switch? Link to comment Share on other sites More sharing options...
nipper Posted April 26, 2015 Share Posted April 26, 2015 Its part 15 in the opposed forces drawing which looks square. Link to comment Share on other sites More sharing options...
subaru forever Posted April 26, 2015 Author Share Posted April 26, 2015 Ok.thanks Link to comment Share on other sites More sharing options...
subaru forever Posted April 26, 2015 Author Share Posted April 26, 2015 Looks like advanced auto has it.and did some part look up Link to comment Share on other sites More sharing options...
lstevens76 Posted April 26, 2015 Share Posted April 26, 2015 Did you try replacing your hazard switch? Someone else had this problem a little while ago and turned out to be a bad hazard switch. Link to comment Share on other sites More sharing options...
subaru forever Posted April 26, 2015 Author Share Posted April 26, 2015 Yes replaced hazard switch with working one.where is flasher relay located.?behind radio? Link to comment Share on other sites More sharing options...
