87 GL Level Front Lift Steering Linkage
Hello
Has anyone only lifted the Front to ~level with the rear without altering the Steering Linkage?
If I use ~ 1-1/4" Blocks above the Crossmember will this necessitate altering the Steering Linkage?
Is there a minimum Front lift distance without altering the Steering Linkage?
I am not looking for an intensive lift at this point...just would like a bit more clearance in the Front. Rear is adequate.
Front has McPherson non-adjustable struts.
Thanks again for any input.
