I'm so ghetto that my first instinct response would be to get the end of seatbelt out of a junker and leave it plugged in on the passenger side till I felt like dealing with wires :)
good luck, I've also got an 05 outback so I also hate the seatbelt dings.
I have a 2005 as well. There is  a method to disable the dings. I'll do a search of my posts and report back.
Found it:
Turn the ignition key to on but DO NOT start the car.
Now buckle and unbuckle the drivers seatbelt about ten or fifteen times QUICKLY and then turn the ignition key to off. Now turn the key on and start the car as normal. If you were successful as I was on my 05 OB, the chime will chime 5 times when you first turn the key to on and then stop. It will also disable the seatbelt warning for the passenger seat.
Edited by brus brother
  • Like 1
