Installed some Saggy spacers to fix my camber and rear height on a WRX strut swap. Have a 10% off code for Paranoid Fabrications for our members.
UltimateSubaru
After putting WRX struts into my Wagon, I ran into a problem with the rear
strut tower reverse-cone shape not centering in the designated chassis
hole, as due to my make-shift changes in the bolt-up design, it was no
longer a match.
Rough fit before:
Final fit with spacer:
This prevented the (rear) strut from fully seating, which caused a minor side-affect, no saggy butt syndrome,
but it also created positive camber (bottom of tire moved inwards = posi?).
This was a huge problem as it affected the handling so, that I did not have much confidence in taking twisteys.
I would have realized this if I properly prepared for the project, tutorials already describe this issue.
I
settled on some saggy butt spacers from Paranoid Fabrications for the
02-07 impreza top mounts I'm using, they took about two days to ship!!
And, per their contact page, you can reach them on FaceBook and they did promptly reply.
I
threw them on and used some silicone grease between the spacers and top
hats to prevent any unwanted noise. Worked like a charm! Rear sits
higher now, the tires are stanced properly, and honestly I have a decent
amount of clearance back there now. I'm about to measure my diff
clearance and post later.
HANDLING IS SOO MUCH BETTER now :D
I'm working on getting some discounts for y'all...
CHA-CHING  B)  PM me for a 10% discount for your spacer needs! http://www.paranoidfabrications.com/
Hey, it's something (10% off an order I believe).
Here's some pics of how it went:
Edited by SnatchedHatch
