86 Brat sputters when I shut if off..
It's called dieseling here in Idaho haha. All ya gotta do is either, like they already said, up the octane for a bit, OR you can hold the throttle open to rev it up and pour a LITTLE bit of water down the intake. Not too much cause it'll hydrolock, but a little tiny bit at a time will clean it out
Are you running the stock hitachi? If so, there should be an Anti-Dieseling solenoid on the side of it to prevent this. Dieseling is sometimes common with the Weber swap because there is no solenoid. What you can do also besides water, is rev the motor up, remove the air filter cover and pour about 1/2 can of Seafoam down the carb, and then either stall it with the Seafoam, or shut it off quick. Let it sit about 15/20min then fire it back up (May take a little bit depending how good your plugs are) it will smoke like hell for a few, but rev the hell out of it, and once it stops smoking so much, take it for a spirited drive and give it a good running to blow out the carbon.
Seafoam will do the same thing as water, but is petroleum based. And personally a better solution. I've done it to ever vehicle so far, Carb or FI.
Here is a good video showing you how to use it correctly.
Edited by TheLoyale
  • Like 1
Use a spray bottle, that way the water is already atomized, and is much easier for the engine to "digest"
  • Like 1
  On 4/29/2015 at 7:21 PM, comatosellama said:
I thought you waned it up, so the chance of hydrolock was decreased because the amount of water per cycle would be decreased
If you are gonna be dumping Seaform down the carb, yes you want to rev it so it'll suck it thru the system and not just bog it out.
For normal running idle, 1000rpm is too high, 700-800rpm is best for normal idle running, this will reduce the likelihood of it dieseling when the ignition is cut off.
  On 4/30/2015 at 11:00 PM, ragingbull said:
Sounds good! Ill dump the Seafoam 1/3 in the gas tank, 1/3 in oil and 1/3 down the carb.. Thanks gents!
Do not use any in the oil unless you have an extremely dirty motor. Just putting it thru the carb and in the fuel will be fine to clean out the air and fuel passages.
And if you do, make sure to change your oil within 100 miles
  • Like 1
If you want a better product, which you can leave in the oil to help clean and add some protection, try using Marvel Mystery Oil. It is an additive which works with all oil types (You can put some of this in your Petrol as well) After you change you oil, I would add about half qt to the fresh oil (DO NOT OVER FILL OIL) and it will help clean out deposits and sludge from short trip driving.
