JustGo_GL Posted April 27, 2015 Share Posted April 27, 2015 Hey folks,So my '84 Subaru GL started sounding a bit differently as it drove quite recently, took the heat shield off and saw that there's a bit of rust on the Y-pipe leaving the engine, and am worried that there might be a few small leaks, though everything else is generally intact, and the pipe hasn't completely shredded itself or anything. Is it risky to keep running in this condition? I've been unable to locate a replacement pipe and I'm scheduled to be going on a long 3K mile journey in the car this coming week. As a note, I can't currently smell anything extra or exhaust-like from the cabin, so that's vaguely reassuring. Link to comment Share on other sites More sharing options...
ihscout54 Posted April 27, 2015 Share Posted April 27, 2015 Pipes are available online listed as a catalytic converter. The ea82 pipes fit (with slight mods) and can be had on ebay for under $130 the ea81s are around $160+. Quality is so so and cheapos wont have the heat sheild except around the cat. They work tho. Keep your window cracked I imagine ull be fine. Or should I say; been there done that, just smoke one less cigarette. Link to comment Share on other sites More sharing options...
DaveT Posted April 27, 2015 Share Posted April 27, 2015 If you are moving forward, the ventilation system makes it unlikely the leaks will harm you. I've driven around withe leaking exhaust pipes for months sometimes. Its just noisy. Link to comment Share on other sites More sharing options...
DaveT Posted April 27, 2015 Share Posted April 27, 2015 If it were to break off while on your long trip, that could be inconvenient. Link to comment Share on other sites More sharing options...
jmoss5723 Posted April 27, 2015 Share Posted April 27, 2015 Seafoam the engine and try to see if any smoke comes out of the suspected leak points. Link to comment Share on other sites More sharing options...
ihscout54 Posted April 27, 2015 Share Posted April 27, 2015 Good thinking Jmoss. If he feels its needed many things will work as a leak detector carb cleaner spray, teaspoons of oil, atf or even a lil water (as an eco freindly option). Link to comment Share on other sites More sharing options...
