perrodelturbo Posted April 28, 2015 Share Posted April 28, 2015 Slight miss around 2000 rpm Rough south of 1200 rpm Stalls out, but starts right back up 900rpm or less Only clue I have so far is I put a new air filter in , symptoms happened at next start Replacing old filter did not Help Link to comment Share on other sites More sharing options...
Olnick Posted April 28, 2015 Share Posted April 28, 2015 Did you securely clamp the airbox shut after you dropped the new filter in? Link to comment Share on other sites More sharing options...
perrodelturbo Posted April 28, 2015 Author Share Posted April 28, 2015 Ya , but still getting fallout from hitting a 200 pound deer on that side , it was a wrestling match, will check for leaks and tweaks , thanks Link to comment Share on other sites More sharing options...
montana tom Posted April 28, 2015 Share Posted April 28, 2015 You may have broken a solder connection inside the MAF. They are prone to problems in those years. If possible, temp. swap one with another car and see if your problems clear up. 1 Link to comment Share on other sites More sharing options...
AdventureSubaru Posted April 28, 2015 Share Posted April 28, 2015 I'll second the mass air flow since you had to mess with it to replace the air filter. Check the connection. Try throwing a junkyard one in its place. Do you have a check engine light on? If not MAF it may be coincidental time for plugs and wires. Link to comment Share on other sites More sharing options...
