ivantruckman Posted April 28, 2015 Share Posted April 28, 2015 1987 gl 4x4 ....Are there any lower control arm bushings out there any more ?. im having problems finding anything . Link to comment Share on other sites More sharing options...
TomRhere Posted April 29, 2015 Share Posted April 29, 2015 Have read on here about Owners trying to replace those bushings and basically destroyed the control arm in tht atempt. Other's have stated they burned-out, drilled-out, the rubber portion then cut the outer shell to remove it. That would be my way of doing so, if I were to atempt that. Then I would do some type of aftermarket bushing insert, made to fit like Nico has done. I do have 2 bushings here for an EA81 control arm, thinking they are the same for EA82's. You can have the bushings I have have here for a small cost plus shipping. I'm open to offers. Link to comment Share on other sites More sharing options...
superpoo93 Posted April 30, 2015 Share Posted April 30, 2015 (edited) On 4/28/2015 at 4:30 PM, ivantruckman said: 1987 gl 4x4 ....Are there any lower control arm bushings out there any more ?. im having problems finding anything . You could always make your own bushing remover, using allthread, nuts and washers. Should press it out easy.. For bushing Call Outback Technolgies USA, this guy will now what you want. They are polyurethane as well Amir Webb (914) 302-2431 sales@obtusa.com Ea82 control arm kit SPF1691K. $35+shipping Double check the part number Edited April 30, 2015 by superpoo93 Link to comment Share on other sites More sharing options...
bratman2 Posted May 1, 2015 Share Posted May 1, 2015 I drilled the rubber out of them on my EA81 Brat. Then cut a groove in it and they came out without too much trouble. Putting them back in was a little more trouble. I finally had to take them and have them pressed in. Link to comment Share on other sites More sharing options...
