starfoxACEFOX Posted April 28, 2015 Share Posted April 28, 2015 Like to know if light reciproating crank case pressure is normal at idle for EJ22E, once the throttle is open gose away.You can also hear it in dip stick when you pull it out, reciproating motion inside the tube. Foxler Link to comment Share on other sites More sharing options...
Fairtax4me Posted April 29, 2015 Share Posted April 29, 2015 Gonna have that on any engine. Not a big deal as long as the PCV valve is clean. Link to comment Share on other sites More sharing options...
starfoxACEFOX Posted April 29, 2015 Author Share Posted April 29, 2015 Gonna have that on any engine. Not a big deal as long as the PCV valve is clean. Thank for side note, just not use to it. On both Porsches I got, there a AOS which like a oversize PCV valve on steroids. So it's absolutely quite at idle with no pressure and Rover V8 crank case way to big. So was little worry about blow by. So drove the wreck 98 around town. Engine didn't give me any problums, even so I could say gear ratio on that auto trans could be better. It need's sport button, I like to keep all my engins at top end all day. >.> Link to comment Share on other sites More sharing options...
