SUBIANO Posted May 1, 2015 Share Posted May 1, 2015 Parts Needed for 1980 1st Gen BRAT GLI am trying to eliminate a slight shaking at higher speeds and would like to get an alignment done. I found about half of the parts I would like to replace, but I am having trouble finding the inner ball-joint assembly parts. Any help would be greatly appreciated. Thank you! (See the attached photo to match the following numbers) What I REALLY need: 4. Lock nuts 5. Boots 6. Snap rings (boot) 7. Ball-joint assemblys 8. Lock washers What I was able to find and already purchased: 1. Dust seals 2. Snap rings 3. Tie rod ends - Outer ball-joints Link to comment Share on other sites More sharing options...
djcommie Posted May 6, 2015 Share Posted May 6, 2015 (edited) I am in the midst of redoing the front end of my 78 Wagon, so bought everything from Amazon, actually! I purchased the bushings for the radius arm, inner control arm bushings, inner tie rod, tie rod ends, ball joints, etc. I already had some strut tops, but RockAuto had those as I remember. Note that Amazon says 'out of stock' on most of that since I bought all the quantities they had! edit: I went to ball joints that used nylock nuts instead of castellated+cotter pin. and reused the factory bolts/nuts since they were still good. Edited May 6, 2015 by djcommie Link to comment Share on other sites More sharing options...
SUBIANO Posted May 6, 2015 Author Share Posted May 6, 2015 Thank you, found and purchased! Were you also able to find replacement boots? Link to comment Share on other sites More sharing options...
djcommie Posted May 8, 2015 Share Posted May 8, 2015 I think they have them as well, I haven't had any trouble finding parts using just Amazon and RockAuto, honestly. Partsgeek got me a gasket set for a Daihatsu I had years ago, but the first two should be fine. I used RockAuto for cross-referencing sometimes and purchasing on Amazon due to my Prime account, but RockAuto really deserves the business since they stock so much for the old Subarus! Link to comment Share on other sites More sharing options...
