Oil pump drive gear flange
Hey y'all!
The inner flange on the oil pump drive gear on my 1988DL Is no longer attached to the gear and is just flopping loosely on the shaft. If I pulled the gear off the shaft and remove this flange completely will the timing belt run true? If I leave it on I am sure that it will eventually damage the belt. I have looked online for a new drive gear and have not been able to find one.
Thanks for all the help!
