bgambino Posted May 4, 2015 Share Posted May 4, 2015 I have a lead on craigslist for a 95 Legacy L It's a girl and its 1:45 mins away so I cant really ask this ... Did they ONLY make the 2.2L that year? That's all I want...I don't want the 2.5 I have a 96 legacy sedan(L) with the 2.2 From what I recall, the 95 did not?? have the egr pipe and the 96 does?? Is it possible if I ever needed to ...to drop the 96 into the 95 I DO NEED it to pass NY state emissions thanks guys Link to comment Share on other sites More sharing options...
Razorthirty Posted May 4, 2015 Share Posted May 4, 2015 (edited) *holds out a spoon and makes airplane noises* Open wide! From wikipedia - "There were two variations of the EJ25D sold in the US market. The engine was introduced in 1996 in the Legacy 2.5GT, LSi, and Legacy Outback." Not trying to be mean, just saying, this probably took longer to post then to find out on the interwebz. Edited May 4, 2015 by Razorthirty 2 Link to comment Share on other sites More sharing options...
Fairtax4me Posted May 4, 2015 Share Posted May 4, 2015 Model year 95 legacy was 2.2 only. 96 engine will drop in just have to use the single port y pipe that matches the heads, use the 95 intake manifold and wiring, and plug the EGR port in the head. Link to comment Share on other sites More sharing options...
AdventureSubaru Posted May 4, 2015 Share Posted May 4, 2015 different exhaust ports but identical motor otherwise. EGR switch can go either way. Link to comment Share on other sites More sharing options...
bgambino Posted May 5, 2015 Author Share Posted May 5, 2015 Fairtax I understand except for one thing if the 95 has the metal pipe running from the intake to the head......and I use the 95 intake manifold and the 96 engine...will there be a hole in the 96 head for the pipe to attach to? Sorry if I missed something tx Link to comment Share on other sites More sharing options...
Fairtax4me Posted May 5, 2015 Share Posted May 5, 2015 So, you want to put the 95 engine into the 96, and your 96 has EGR? 95 will have EGR if its an automatic. That would be best case in your scenario. Link to comment Share on other sites More sharing options...
bgambino Posted May 5, 2015 Author Share Posted May 5, 2015 sorry I confused anyone I thought the 95 had no egr pipe and the 96 did...(both automatics)...am I wrong? If they both have it then I am golden I want to save the 96 engine in case I ever need to put in the 95 (which I am considering buying...its 1.5 hours away though) Link to comment Share on other sites More sharing options...
upnorthguy Posted May 5, 2015 Share Posted May 5, 2015 As Fairtax said, 95 Auto EJ22 has EGR. Link to comment Share on other sites More sharing options...
Fairtax4me Posted May 5, 2015 Share Posted May 5, 2015 If the 95 is automatic it will likely have EGR. Keep the single port exhaust y-pipe with the 96 engine. You'll need it if you ever do the swap. Link to comment Share on other sites More sharing options...
AdventureSubaru Posted May 5, 2015 Share Posted May 5, 2015 There's an easy bypass to put a non EGR motor mated to an EGR intake manifold and get no check engine light. With all the swaps going on it should probably get a sticky or a spot in the repair manual. You just run a breather hose from that metal pipe to the air hose for the IACV. I used an extra vac hose from the valve cover and ran it to a brass T fitting from home depot. $3. fitting and 2 hose clamps and a bit of pushing and wiggling and bingo! No check engine light. Have had 2 such cars and both passed california smog check. Link to comment Share on other sites More sharing options...
idosubaru Posted May 6, 2015 Share Posted May 6, 2015 to summarize = no EJ25's in 1995. It's only EJ22 and EJ18 int he impreza. 1995 auto has EGR 1995 manual does not have EGR 1996 - can have EGR or not have EGR - there's no way to know without just looking at it. 1996 engine can go in the 95 if you also swap the exhaust manifold. If the 96 doesn't have EGR - do the work around mentioned above. Link to comment Share on other sites More sharing options...
