97 impreza obs auto rear banging rattling clicking constantly
Occasionally a loud bang and the car lurche's while the back end dips and seems to lock up. The sound is constant and there is no 4WD any longer. It's a clanking clicking noise coming from the rear end and is worse when taking turns (currently worse during left handers).
We think it's the clutch pack. If so is there any way to remove them without replacing?
Sounds like a broken axle. Have you been out off-roading?
Checked the rear diff fluid for chunks?
Is it any different if you put the FWD fuse in?
If you think its the clutch pack just remove the rear section of the driveshaft.
No Offroading. FWD fuse fixed it for a while until it just stopped working and never turned back on with a new fuse.
If we remove the rear section do we have to plug anything?
