gar52hpny Posted May 10, 2015 Share Posted May 10, 2015 Hello, My warning light goes on and off intermently. I am looking for solutions to resolve. Link to comment Share on other sites More sharing options...
nipper Posted May 11, 2015 Share Posted May 11, 2015 Which warning light, how many miles are on the car, what maintenance has been done on it Link to comment Share on other sites More sharing options...
Rooster2 Posted May 11, 2015 Share Posted May 11, 2015 I am guessing your are referring to the check engine light. When lit, have the code read at an auto parts store. They will do that in their parking lot at no cost. The code will give you advise, as to what the problem is. Link to comment Share on other sites More sharing options...
lstevens76 Posted May 11, 2015 Share Posted May 11, 2015 Even when not lit it should be storing that code. Pull the code, as Rooster said, and post it, that will give us the information to help you. Link to comment Share on other sites More sharing options...
gar52hpny Posted May 13, 2015 Author Share Posted May 13, 2015 CHECK ENGINE CODES FROM AUTO ZONE: 1. P0301 2. P0302 3. P0303 4. P0304 5. P0420 6. P0172 7. P0106 8. P1137 I look forward to hearing from you. Gerry Link to comment Share on other sites More sharing options...
nipper Posted May 13, 2015 Share Posted May 13, 2015 disonnect the battery for ten minutes, then connect it have the codes re-read. Lets make sure these are active codes and not old codes. P0301 Cylinder 1 Misfire Detected P0302 Cylinder 2 Misfire Detected P0303 Cylinder 3 Misfire Detected P0304 Cylinder 4 Misfire Detected 420 is an O2 sensor When was the last time this car had a tuneup? Link to comment Share on other sites More sharing options...
nipper Posted May 13, 2015 Share Posted May 13, 2015 And we need to know mileage. When was the last time the timing belt was changed (never I am guessing). Link to comment Share on other sites More sharing options...
lstevens76 Posted May 13, 2015 Share Posted May 13, 2015 I would start with the MAP sensor issue + a tuneup and then go from there. It's possible the map sensor is causing it to run rich which is setting off the cat codes, but it does look like you have a possible bad o2 sensor as well. And as fairtax said, how many miles and when was the last timing belt? Link to comment Share on other sites More sharing options...
gar52hpny Posted May 13, 2015 Author Share Posted May 13, 2015 MILEAGE: 160K TUNEUP: 120K TIMING BELT CHANGED: 120K, 140K the belt self adjust part jammed, belt broke, valves jammed, had valve job done at subaru dealer. Link to comment Share on other sites More sharing options...
nipper Posted May 14, 2015 Share Posted May 14, 2015 Reset all the codes and get another reading. What parts were replaced with the timing belt. Link to comment Share on other sites More sharing options...
gar52hpny Posted May 14, 2015 Author Share Posted May 14, 2015 WHAT PARTS WHERE REPLACED WHEN THE BELT WAS REPLACED: 1. AUTOMATIC BELT TENSIONER 2. WATER PUMP 3. BEARINGS 4. TIMING ADJUSTMENT Link to comment Share on other sites More sharing options...
gar52hpny Posted May 20, 2015 Author Share Posted May 20, 2015 Reset all the codes and get another reading. What parts were replaced with the timing belt. Link to comment Share on other sites More sharing options...
gar52hpny Posted May 20, 2015 Author Share Posted May 20, 2015 How do I reset all the codes and get another reading. Link to comment Share on other sites More sharing options...
