jalbert300 Posted May 14, 2015 Share Posted May 14, 2015 Hi, I have a 2001 Forester with 180K that recently starting making a popping noise in the rear. My impression is that the struts need to be replaced, but would like an opinion from this forum. I made a video and highlighted the noise in the first minute, but the noise can be heard through out the video, especially from 2:40 - 3:10. Here is the link to youtube video. If anyone can help with a diagnosis I would greatly appreciate it! Thanks, Jon Quote Link to comment Share on other sites More sharing options...
forester2002s Posted May 14, 2015 Share Posted May 14, 2015 Can't help you with a diagnosis, but that's a great video! Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted May 14, 2015 Share Posted May 14, 2015 can't imagine very many original struts with 180K being in top condition.wouldn't hurt to inspect other components too when installing the struts. Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted May 14, 2015 Share Posted May 14, 2015 Neat video! But that noise isn't the struts. If it is coming from the rear of the car, it's going to be something damaged in the rear diff or a broken axle. Drain the diff fluid, look for chunks. Quote Link to comment Share on other sites More sharing options...
jalbert300 Posted May 14, 2015 Author Share Posted May 14, 2015 Thanks for the feedback, rear differintial I assume can get expensive. I will look into draining fluid. I have little to no work on my car myself, hopefully something I can handle. Sometimes the noise(s) make me feel like the whole rear end is falling apart, but have had the car looked at several times recently and nobody has showed any concern or displayed confidence in what the noise is. One thing I found interesting in the video is that immediately after going over man hole cover you can hear a single pop. Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted May 14, 2015 Share Posted May 14, 2015 (edited) It's an automatic right? You can put the front wheel drive fuse in and see if the noise changes. The loud crunch/grind going from reverse to drive is something drivetrain/axle related. Struts don't make noise when you're sitting still. The drain and fill plugs on the rear diff can be grizzly bear tight and very difficult to get loose. They typically require quite a bit of leverage, which means you need lots of room under the car. Edited May 14, 2015 by Fairtax4me 1 Quote Link to comment Share on other sites More sharing options...
jalbert300 Posted May 14, 2015 Author Share Posted May 14, 2015 Yes it is automatic. I didn't know you could switch to FWD, I will give that a shot and see how it sounds. Would be unfortunate, but is there anything wrong with leaving in FWD permanently to avoid spending money on repairs? Quote Link to comment Share on other sites More sharing options...
jalbert300 Posted May 14, 2015 Author Share Posted May 14, 2015 Never mind on permanent FWD, little bit of research tells me you to bad idea. I will just be sure the for diagnostic purposes. Quote Link to comment Share on other sites More sharing options...
jalbert300 Posted May 14, 2015 Author Share Posted May 14, 2015 Damn spell checker... Lol Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted May 14, 2015 Share Posted May 14, 2015 With the vehicle in FWD all of the rear drive peices will still be turning whenever the vehicle is moving. So even if the noise goes away, whatever is causing the noise can still be an issue if it later decides to let go entirely. If the noise does go away then we can say with at least some certainty that the origin is in the rear drive components. If the noise gets worse, then there is a high probability that the noise is related to a front axle or differential problem. Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted May 14, 2015 Share Posted May 14, 2015 u-joint is another possibility. just weird that it so intermittent. Quote Link to comment Share on other sites More sharing options...
jalbert300 Posted May 14, 2015 Author Share Posted May 14, 2015 One mechanic did mention u-joint as possible cause... I just took for a spin in FWD and nothing changed good or bad, same noise... Quote Link to comment Share on other sites More sharing options...
jalbert300 Posted May 14, 2015 Author Share Posted May 14, 2015 Here is a video of the rear passenger side strut. It seems to be making some of the noise! And for good measure, here is a video of the U-Joint which seems to be fine... To much time on my hands... lol Quote Link to comment Share on other sites More sharing options...
jalbert300 Posted May 14, 2015 Author Share Posted May 14, 2015 If anyone is still listening to this, scratch everything I have said or shown... I now think the noise is from the "sway bar links...", see video below... I recently had the rear brake calipers replaced, and suppose the sway bar links were removed to do the job. Maybe they should have replaced those instead of putting the old ones back on, or greased them better??? Sounds reasonable? Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted May 14, 2015 Share Posted May 14, 2015 they should not have been removed but, they can and do break - as well as sway bar mounts. should be easy to spot if they are invlved in the noise. Quote Link to comment Share on other sites More sharing options...
jalbert300 Posted May 14, 2015 Author Share Posted May 14, 2015 K thanks for the help, if nothing else I've prevented someone from talking me into dumping money on struts when it may not be newscast. Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted May 14, 2015 Share Posted May 14, 2015 Sway bar links usually make more of a low clunk sound that what you have. But I've seen the bolts come loose and they make some interesting noises. Easy to check. Just unbolt them and go for a ride. Quote Link to comment Share on other sites More sharing options...
lstevens76 Posted May 14, 2015 Share Posted May 14, 2015 Holy cow, just watched that first video finally. I know everyone was saying the noise wasn't struts, but did anyone pay attention to the bounce? I would put money both those rear struts are bad and based on a later video I would suspect strut mounts as well. Quote Link to comment Share on other sites More sharing options...
jalbert300 Posted May 14, 2015 Author Share Posted May 14, 2015 I agree the struts could probably use replacing, but the biggest thing annoying me is the dang noise back there. Going to try SOOBEROOs advice of unbolting the sway bar links and see what happens... With that said, anybody know what a fair price for replacing rear Struts and Mounts is? Quote Link to comment Share on other sites More sharing options...
lstevens76 Posted May 14, 2015 Share Posted May 14, 2015 Always start with the obvious. The struts are bad and that can cause all kinds of noises. Creaks, pops, etc... from stuff shifting differently that is meant to. It can also damage other suspension components and put additional wear on them. It's a 12MM, 17MM, and 19MM sockets to do it yourself, IIRC. Then a spring compressor rental (most parts stores you pay then get a full refund when you return it). Rockauto.com has your rear struts KYB Excel-G for $68.00 each strut then $48.00 for each strut mount and they have FCS (haven't heard of them mysefl) completely assemblies with new springs and mounts for $127.00. Automd.com can show you the labor hours for it, but I suspect it's between 1 and 2 hours. Quote Link to comment Share on other sites More sharing options...
jalbert300 Posted May 14, 2015 Author Share Posted May 14, 2015 cool, thanks for the info! Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted May 15, 2015 Share Posted May 15, 2015 The problem is the creaking and popping that happens when the strut is NOT moving. I hear a lot of noises in those videos that don't correlate to any movement of the suspension. Did you record the drivers side as well? Any noises on that side? Quote Link to comment Share on other sites More sharing options...
jalbert300 Posted May 15, 2015 Author Share Posted May 15, 2015 I didn't record the driver side strut, but the last video of sway bar link is the driver side. I assume the noise in that video is the sway bar link, and that seems to me like where the popping is coming from. I may be hearing with my eyes though... Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted May 15, 2015 Share Posted May 15, 2015 Ahh I missed that video. Reach under there with a 14mm socket and 14mm wrench and try to tighten the bolts on that link. Quote Link to comment Share on other sites More sharing options...
brus brother Posted May 15, 2015 Share Posted May 15, 2015 Is there ANY seepage of oil from the struts? Not that this is necessarily diagnostic BUT during last winter, I noticed all sorts of noises coming from the rear of my 05 OB and the car was skipping all over the road after I hit a bump. Replaced struts (leaking) and sway bar links (had some play) and all was well. Bought KYB struts from local Autozone with a price match to someone else on-line and got the sway bar links there as well. It's a dirty job and was way too cold so I had a Subie tech work on it after hours for $150 labor. Quote Link to comment Share on other sites More sharing options...
