jalbert300 Posted May 15, 2015 Author Share Posted May 15, 2015 No leaking... $150 now that's a deal Link to comment Share on other sites More sharing options...
lstevens76 Posted May 15, 2015 Share Posted May 15, 2015 Just an FYI, a strut doesn't have to leak to have failed. And that was probably $50/hr to do the rears so that's a good deal. Seems it's a 3.2hr job, but that is only if your changing the springs. I would suspect a full assembly could be done in under 2 hours, both sides. Link to comment Share on other sites More sharing options...
jalbert300 Posted May 15, 2015 Author Share Posted May 15, 2015 So here is a video of the Driver Side Rear Strut. Ton of noise from back there, does it sound like the strut, or strut mount? (At 1:43 it sounds like the world is caving in...) I lubed the hell out of everything in the back, and removed the sway bar links. Going to put new links in tomorrow, but they were not the culprit. I feel like an obsessed mad man, but having some fun and learning as well. I get the feeling I just need to get rear struts(at least) and move on with my life Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted May 16, 2015 Share Posted May 16, 2015 can you create any noise bouncing the 2 rear corners? Link to comment Share on other sites More sharing options...
jalbert300 Posted May 16, 2015 Author Share Posted May 16, 2015 Not after lubing everything. Only noise I can hear bouncing it now is the air noise the struts make. Link to comment Share on other sites More sharing options...
jalbert300 Posted May 29, 2015 Author Share Posted May 29, 2015 Update... The noise was 100% from the Strut Mounts. I took the Forester in to have all 4 struts and mounts replaced, but for some reason the Mechanic didn't replace the mounts. Oops... After driving away and still hearing the noise, I took it back and confirmed they didn't replace the mounts. They realized their mistake, put the new mounts in for cost of parts only, and the noise went away 100%!!! Total damage was $900 for everything. Happy Camper! Link to comment Share on other sites More sharing options...
