darsdoug Posted May 16, 2015 Share Posted May 16, 2015 I searched for an hour and couldn't find a pic showing power steering fluid leaking from the hole on the back/bottom of a power steering pump. On my Legacy it appears to be puddling on top of the block just behind and below the pump where the hole is. Is that a relief passage that allows fluid to escape when a seal fails internally? Link to comment Share on other sites More sharing options...
lstevens76 Posted May 16, 2015 Share Posted May 16, 2015 It's probably tHe o-ring that is on the bottom of the reservoir Link to comment Share on other sites More sharing options...
Rooster2 Posted May 16, 2015 Share Posted May 16, 2015 EZ to fix, o-ring available from dealer. Can't remember exactly how to replace the o-ring, but it is intuitive, once you see the size of the o-ring. The Subie counter parts guy will show you how, and where to install. Link to comment Share on other sites More sharing options...
