impostor Posted May 17, 2015 Share Posted May 17, 2015 I have the engine out of my brat to replace the crank and rod bearings and I noticed the ring gear teeth are pretty chewed up. I can't seem to find a new replacement anywhere. Even just a new ring gear would be OK. As a last resort I could rotate the ring gear but I would rather just replace the thing. Anyone have any leads? Link to comment Share on other sites More sharing options...
moosens Posted May 17, 2015 Share Posted May 17, 2015 Used is what I have resorted to. Thanks or the reminder , I need to swap mine for the same reason. And as you probably know already it'll always be on that chewed spot when you are in front of a crowd. Something most morons don't understand and they snicker as if your car is a pos. 1 Link to comment Share on other sites More sharing options...
impostor Posted May 29, 2015 Author Share Posted May 29, 2015 Ended up just rotating the ring gear 90 degrees. Working great so far. Link to comment Share on other sites More sharing options...
