CRAZY tach needle jump timing issue
I was driving my EA82 1987 GL (Weber carb) today, and all of a sudden, the tach needle went all haywire, started reading 4-5k rpm (even though the engine was still at about 2k). On top of that, the timing was all screwy, and the car pinged badly under load.
Less than a minute later, the issue was gone, and only came back later in the day, under hard acceleration. Again, only for a minute. The car is running a bit hot, but is not overheating or anything (need to replace the radiator, I think). I was thinking that this could be the coil, but the tach is connected to the distributor, not the coil.
Do I need a new distributor or something?
Probably.
Take the cap off and check for side play in the shaft.
Anything more than barely detectible is too much,
Common problem.
  • Like 1
