benjamachine Posted May 26, 2015 Share Posted May 26, 2015 I was driving my EA82 1987 GL (Weber carb) today, and all of a sudden, the tach needle went all haywire, started reading 4-5k rpm (even though the engine was still at about 2k). On top of that, the timing was all screwy, and the car pinged badly under load. Less than a minute later, the issue was gone, and only came back later in the day, under hard acceleration. Again, only for a minute. The car is running a bit hot, but is not overheating or anything (need to replace the radiator, I think). I was thinking that this could be the coil, but the tach is connected to the distributor, not the coil. Do I need a new distributor or something? Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted May 26, 2015 Share Posted May 26, 2015 Not the Distributor itself, but maybe the Ignition Module is saying Goodbye... However, I kindly suggest you to Disconnect the Battery, and check the Distributor's Wirings, maybe it has a loose one. Good Luck! Kind Regards. Quote Link to comment Share on other sites More sharing options...
naru Posted May 26, 2015 Share Posted May 26, 2015 I was driving my EA82 1987 GL (Weber carb) today, and all of a sudden, the tach needle went all haywire, started reading 4-5k rpm (even though the engine was still at about 2k). On top of that, the timing was all screwy, and the car pinged badly under load. Less than a minute later, the issue was gone, and only came back later in the day, under hard acceleration. Again, only for a minute. The car is running a bit hot, but is not overheating or anything (need to replace the radiator, I think). I was thinking that this could be the coil, but the tach is connected to the distributor, not the coil. Do I need a new distributor or something? Probably. Take the cap off and check for side play in the shaft. Anything more than barely detectible is too much, Common problem. 1 Quote Link to comment Share on other sites More sharing options...
benjamachine Posted May 26, 2015 Author Share Posted May 26, 2015 Thanks, all! Quote Link to comment Share on other sites More sharing options...
ragingbull Posted May 27, 2015 Share Posted May 27, 2015 I had the same problem. Ended up being my distributor. . Quote Link to comment Share on other sites More sharing options...
