lmdew Posted May 28, 2015 Share Posted May 28, 2015 I just picked up a 97 OBS project - 281K - Clutch was totally out, the center had broken out of the disk. A cheap clutch for sure - I put a good clutch in, the trans shifts fine, up and down but will not go into 4th. I have not checked the linkage yet. - The Trans input shaft did have a little play, but not bad for 281K I'm thinking a used trans,but thought I'd ask. Thanks, Larry Link to comment Share on other sites More sharing options...
Fairtax4me Posted May 28, 2015 Share Posted May 28, 2015 (edited) Bad mainshaft bearing would be my guess. Lets the shaft walk fore/aft and it knocks the center out of the clutch hub. 4th is usually the first gear to go when the bearing goes bad. Edited May 28, 2015 by Fairtax4me Link to comment Share on other sites More sharing options...
lmdew Posted May 28, 2015 Author Share Posted May 28, 2015 Repair this trans or replace it with a used one? UPAP trans are only $125 and not to hard to find, so I'm thinking replace the trans and then when I have more time I could split this one and see how bad things are inside. Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted May 28, 2015 Share Posted May 28, 2015 281K? - I'd find a used trans Link to comment Share on other sites More sharing options...
Fairtax4me Posted May 28, 2015 Share Posted May 28, 2015 Easiest to pop a used trans in it. The bearing costs about $65 IIRC, then you have to tear down the trans, press the old one off and the new one on. A good 3-4 hours between disassembly cleaning and reassembly. Link to comment Share on other sites More sharing options...
AdventureSubaru Posted May 28, 2015 Share Posted May 28, 2015 4th gear goes first. This seems typical of how a 5mt dies. I'd find a good used one as well. OBS should be same final drive as most legacies. As I recall just about anything that came with a EJ18 or EJ22 had the same final drive. There's a chart for 5MTs somewhere that's handy to print and take to the junkyard to confirm the trans code and final drive. Link to comment Share on other sites More sharing options...
lmdew Posted May 28, 2015 Author Share Posted May 28, 2015 Thanks, used is the way I'll go. Link to comment Share on other sites More sharing options...
86BRATMAN Posted May 29, 2015 Share Posted May 29, 2015 https://docs.google.com/file/d/0BzTxUgzNAbd8cEJjXzN2Znk5djg/edit?usp=docslist_api Here's a link to that transmission code list. Link to comment Share on other sites More sharing options...
