Where to get new water pump bolts?
Hi giys, I  just bought a donor 95 subaru that was wrecked with 146,000 miles on the ej22 for a subaru swap into my volkswagen and I began disassemblling to clean and replace the timing belt, idlers, and water pump. I had no trouble until I needed to remove the water pump, which was pretty clapped out. Long story short  the 6 10mm bolts that came out need to be replaced because I broke one off and 2 others are in disrepair. I used an impact after letting them soak with pb blaster. Where can I find some new bolts? dealership is out of the question since the nearest one is over 2 hours away. Can someone direct me to a good parts supplier that will carry them?
Thanks
Bret
Edited by bret2094
