bret2094 Posted May 29, 2015 Share Posted May 29, 2015 (edited) Hi giys, I just bought a donor 95 subaru that was wrecked with 146,000 miles on the ej22 for a subaru swap into my volkswagen and I began disassemblling to clean and replace the timing belt, idlers, and water pump. I had no trouble until I needed to remove the water pump, which was pretty clapped out. Long story short the 6 10mm bolts that came out need to be replaced because I broke one off and 2 others are in disrepair. I used an impact after letting them soak with pb blaster. Where can I find some new bolts? dealership is out of the question since the nearest one is over 2 hours away. Can someone direct me to a good parts supplier that will carry them? Thanks Bret Edited May 29, 2015 by bret2094 Link to comment Share on other sites More sharing options...
AdventureSubaru Posted May 29, 2015 Share Posted May 29, 2015 pm me your address and I can put some rust free california ones in the mail to you tomorrow. How many do you want? Link to comment Share on other sites More sharing options...
