firstsubi Posted May 29, 2015 Share Posted May 29, 2015 I thought I had a bad wheel bearing, so I dropped the car off at my mechanic... He calls me today and said he isn't sure what the noise is or where it's coming from but his money would be on the rear... I thought that sounded highly unlikely. I've never seen someone on here talking about issues with the rear!!! Any suggestions how to check it or has anyone had or heard of it going bad? I know it's a moving part so it is possible to go bad but I think there are too many other things first.... And as far as still thinking wheel bearing, the hub that I believe is the culprit gets hotter then the other side hub after driving. One is hot to the touch the other barely warm? Thanks Link to comment Share on other sites More sharing options...
soopsoop Posted July 3, 2015 Share Posted July 3, 2015 go to a proctoligist either that or one of your brakes are dragging,might have oil on it. Link to comment Share on other sites More sharing options...
johnceggleston Posted July 3, 2015 Share Posted July 3, 2015 (edited) chances of it being a bad rear diff is really, really, low, unless it ran out of gear oil. have someone drive while you sit in the back listen to see which side has a louder noise. that is the bad wheel bearing. Edited July 3, 2015 by johnceggleston Link to comment Share on other sites More sharing options...
wagonist Posted July 6, 2015 Share Posted July 6, 2015 You may not have heard about it, but that prob cos the people on here know that wheel bearings go bad after a time & they need changing. It happens with every car. And it's not the easiest job to go on the rear of the subie unfortunately... Link to comment Share on other sites More sharing options...
idosubaru Posted July 7, 2015 Share Posted July 7, 2015 rear differentials rarely fail in Subarus - it's probably a mis-diagnosis as often, or more, than an actual failed rear diff. let's start with the basics...what lead you to believe it was a wheel bearing? you mentioned heat... 1. noises? 2. drivability? Link to comment Share on other sites More sharing options...
firstsubi Posted July 10, 2015 Author Share Posted July 10, 2015 It's a wheel bearing. I'm having a hell of a time with the ring nut tho. Link to comment Share on other sites More sharing options...
turbosubarubrat Posted July 10, 2015 Share Posted July 10, 2015 It's a wheel bearing. I'm having a hell of a time with the ring nut tho. Your going to probably have to heat it up with a torch, hit it, and spray it with penetrating oil. Link to comment Share on other sites More sharing options...
