Struggling with this Timing belt, the printed marks are not working and I'm looking to confirm tooth count between cams and crank. It's a '99 EJ25 Forester.
I've done a couple of these and not had this problem, it's a Gates TCK304  223 tooth belt.
 Going by this recent thread, I marked up the belt in the attached photo
http://www.ultimatesubaru.org/forum/topic/152228-got-some-strange-specs-on-timing-belt/?hl=%2Btiming+%2Bbelt
It seems like if the P side cam and crank will align, when I try to hook the d side cam, it is off several teeth.
The marks I made here are counted from the left mark on the belt.
