silverhelme Posted June 1, 2015 Share Posted June 1, 2015 The '91 Legacy uses 2 different types of injectors, one for automatics and one for manual transmissions. Does anyone know if they are interchangeable? The one for autos is about twice as expensive as the manual and from the pictures I have seen they are the same except for the pintle that covers the tip. Anyone know if the manuals can be used in place of the autos without changing out the fuel lines? Link to comment Share on other sites More sharing options...
Legacy777 Posted June 1, 2015 Share Posted June 1, 2015 No, they are not easily interchangeable. I believe the fuel rails are different as well. You can use the newer red top injectors, but would need to swap the rails and ECU. Some of the pins are slightly different as well, so the easiest thing is to just use the injectors meant for the 90-91 auto trans legacies. Link to comment Share on other sites More sharing options...
lstevens76 Posted June 1, 2015 Share Posted June 1, 2015 New can be expensive but you could also try used ones from a local pick-a-part or try http://www.witchhunter.com/ to have them serviced and cleaned. Link to comment Share on other sites More sharing options...
silverhelme Posted June 2, 2015 Author Share Posted June 2, 2015 (edited) New can be expensive but you could also try used ones from a local pick-a-part or try http://www.witchhunter.com/ to have them serviced and cleaned. That's great. It's only a 240 mile round trip to the nearest pick a part. Edited June 2, 2015 by silverhelme 1 Link to comment Share on other sites More sharing options...
86 Wonder Wedge Posted June 3, 2015 Share Posted June 3, 2015 Damn, there was a 91 Auto at my local PAP, should have pulled those injectors..... Probably off to China by now.. Link to comment Share on other sites More sharing options...
silverhelme Posted June 3, 2015 Author Share Posted June 3, 2015 When I installed the motor it had 2 dead cylinders that turned out to be stuck injectors. when I started hunting for injectors i found that the ones I have are the expensive ones. Now I have one more that is giving me problems and was just wondering if the manual ones interchange,they look the same except for the pintle. NAPA wants $134 and the cheapest I can find elsewhere is about $75 for rebuilt. Link to comment Share on other sites More sharing options...
86 Wonder Wedge Posted June 3, 2015 Share Posted June 3, 2015 Have you tried soaking them in seafoam (or similar decarbonizer) and then trying to manually pulse them (with a battery source, but look up the voltage specs first. I think they are low voltage IIRC)? You might able to save them... Link to comment Share on other sites More sharing options...
lstevens76 Posted June 3, 2015 Share Posted June 3, 2015 A quick search of car-part.com came up with: 1990 Fuel Distributor(& Misc. Inj.) Subaru Legacy RIGHT RAIL W/ 2 INJECTORS AUTO TRAN A 7C0444 $20 All Star Auto Parts USA-MN(Princeton) E-mail 1-763-631-9104 I can pull a full set at my local pick-a-part (if they have them) for $24 ($6/each) so the road trip may be worth it if they are cheap enough. You could also send them in, as I noted above, and spend a lot less than even a rebuilt one cost that you quoted. Another option would be to see if there is a local shop that does fuel injector service. Link to comment Share on other sites More sharing options...
silverhelme Posted June 4, 2015 Author Share Posted June 4, 2015 A quick search of car-part.com came up with:1990Fuel Distributor(& Misc. Inj.) Subaru Legacy RIGHT RAIL W/ 2 INJECTORS AUTO TRAN A 7C0444 $20 All Star Auto Parts USA-MN(Princeton) E-mail 1-763-631-9104 I can pull a full set at my local pick-a-part (if they have them) for $24 ($6/each) so the road trip may be worth it if they are cheap enough. You could also send them in, as I noted above, and spend a lot less than even a rebuilt one cost that you quoted. Another option would be to see if there is a local shop that does fuel injector service. I may need to flush the fuel rails as I am seeing garbage on the ones I am pulling out. As far as a local shop, there is only one and I used to work there. I was the second best mechanic there, the best mechanic and I retired and the 2 kids that got hired I wouldn't trust to change a tire much less work on a fuel system. Link to comment Share on other sites More sharing options...
lstevens76 Posted June 4, 2015 Share Posted June 4, 2015 I meant a local fuel injector service shop. We have one where I live and that's it. The rest are just general shops, not injector specialty shops. Link to comment Share on other sites More sharing options...
silverhelme Posted June 6, 2015 Author Share Posted June 6, 2015 By local you must mean Spokane, a 240 mile round trip. That would be the nearest place with a rebuild shop. As far as used injectors, you take you chances with those also especially when they have sat for a while. Link to comment Share on other sites More sharing options...
lstevens76 Posted June 6, 2015 Share Posted June 6, 2015 (edited) I hadn't looked to see where your at but if your in the Northwest there is one in Boise as well. You could also ship them, as I said above, or buy a used set and have them shipped to you. All I was pointing out is buying new ones isn't the only option and there are a lot cheaper options. As for taking a chance on used ones, you are right. But if you buy 4 used ones for say $60 shipped and send them into witchhunter.Com to be refurbished your still spending less than new. Edited June 6, 2015 by lstevens76 Link to comment Share on other sites More sharing options...
Fairtax4me Posted June 6, 2015 Share Posted June 6, 2015 Look in the classifieds here. Pretty sure someone will have a used set they can send you a whole lot cheaper than buying 4 new/reman ones. Link to comment Share on other sites More sharing options...
mikaleda Posted June 6, 2015 Share Posted June 6, 2015 just go to the junk yard and pull the entire rail. the injectors are the same in any 90-99 ej22 it doesnt matter if they are auto or manuel as long as you change the whole rail out. im using injectors out of a 96 auto in my 90 manuel Link to comment Share on other sites More sharing options...
silverhelme Posted June 7, 2015 Author Share Posted June 7, 2015 just go to the junk yard and pull the entire rail. the injectors are the same in any 90-99 ej22 it doesnt matter if they are auto or manuel as long as you change the whole rail out. im using injectors out of a 96 auto in my 90 manuel That is the information I was looking for to start with. As a retired mechanic I've dealt with "rebuilt" injectors and as a rule have found that the quality is lacking. Most of the time good used ones are a better choise as long as they haven't sat and varnished up. Link to comment Share on other sites More sharing options...
silverhelme Posted June 7, 2015 Author Share Posted June 7, 2015 (edited) Has anyone thought about machining adapter bungs to use standard injectors and rails on the EJ22? I doesn't look like it would be all that hard. Edited June 7, 2015 by silverhelme Link to comment Share on other sites More sharing options...
lstevens76 Posted June 7, 2015 Share Posted June 7, 2015 (edited) The reason I recommended witchhunter.Com is because they have a good solid reputation for rebuilding and checking injectors. Unlike rebuilt ones they yest and rebuild the ones you send in. They are fairly well known in the tuning community. Edited June 7, 2015 by lstevens76 Link to comment Share on other sites More sharing options...
