dssenne Posted June 5, 2015 Share Posted June 5, 2015 I'm looking to replace the ECU on my '92 Legacy. It's a FWD wagon. The sticker on the ECU is below: I found one online that has the same number, except that there's an F at the end (22611 AA930). They told me that it came out of a '92 Legacy, but if I get it and it turns out to not be the right one, I'm just out of luck. I've also seen ones that end in AA931. Mine also has the number A18-000RF6, but the ones online generally only list the 10 digit # above. Do you think that the one I found that ends in AA930F will work for me? Thanks! Link to comment Share on other sites More sharing options...
dssenne Posted June 5, 2015 Author Share Posted June 5, 2015 They told me that it would work for me, so I went a head and ordered it. We'll see. At least it was only around $80 including shipping. Link to comment Share on other sites More sharing options...
johnceggleston Posted June 5, 2015 Share Posted June 5, 2015 why do you need an ECU? they do not fail often. did you look at http://www.car-part.com ? it should be listed under computer, i think. Link to comment Share on other sites More sharing options...
dssenne Posted June 9, 2015 Author Share Posted June 9, 2015 why do you need an ECU? they do not fail often. did you look at http://www.car-part.com ? it should be listed under computer, i think. After posting here and talking to my local mechanic, it seemed like the ECU was the only reason left why my main cooling fan didn't work. Bought one and put it in today, and it solved my problem. Paid $80 including shipping, so I'm happy. Link to comment Share on other sites More sharing options...
wtdash Posted June 11, 2015 Share Posted June 11, 2015 (edited) Just for reference, the 'F' means it was made in the USA, but is compatible - as you discovered. - Early USDM Legacys were made in the USA and Japan (except for '91-'94 turbo models were all from Japan) - as were their components. - The MAF sensors also have an 'F' version for the US-made part, FWIW. glad you're back up and running. Td Edited June 12, 2015 by wtdash Link to comment Share on other sites More sharing options...
idosubaru Posted June 12, 2015 Share Posted June 12, 2015 next time you can also post on a forum like this and ask, some of us have ECU's (and other parts) lying around - and ECU's fail so rarely they're nearly worthless, can't get $5 for them. there's a classified forum. Link to comment Share on other sites More sharing options...
dssenne Posted June 12, 2015 Author Share Posted June 12, 2015 Thanks for the info! And I'll check out the classified forum next time. Considering how much they probably cost new, I felt pretty good getting one for $80, but less is always good. Link to comment Share on other sites More sharing options...
idosubaru Posted June 12, 2015 Share Posted June 12, 2015 yeah they're sick new, i can't believe anyone buys them. sure $80 is good, just a note for future reference if you run across any hard to find, etc parts. Link to comment Share on other sites More sharing options...
