ivantruckman Posted June 5, 2015 Share Posted June 5, 2015 Is it hard to convert a ea82t to a ea82, I have an opportunity to get a nice T wag with bad head gaskets . Is it as easy as putting in a ea82 , or is there a different ecu and wiring harness crap ?. Link to comment Share on other sites More sharing options...
SoobDood05 Posted June 6, 2015 Share Posted June 6, 2015 The ecu is definatley different., not too sure on the harness but there is obviously going to be different wires running for things non turbo doesent have. maybe someone else can chime in if they have done this conversion. good luck! Link to comment Share on other sites More sharing options...
ihscout54 Posted June 9, 2015 Share Posted June 9, 2015 Im sure its been done. If your looking at a turbo/mpfi swap to spfi there will definately be harness differences just the injector wiring is one obvious difference. I cant see the exhaust being the same. Did the 86 ea82t use a flapper MAF? Another difference there. I really have nothing of value to add to your thread other than using a carbed ea82 would make things pretty easy. Of course, thats if you can find one. Or if your like me and cant stand driving a carbureted car. Link to comment Share on other sites More sharing options...
wagonist Posted June 9, 2015 Share Posted June 9, 2015 turbo is MPFI. You can swap in an NA MPFI engine with it's matching ECU, but the SPFI will be a completely different wiring harness throughout the car. ditto with the carb wiring. If you've got a complete SPFI car, then just swap the lot over. It's not hard, just need time. Link to comment Share on other sites More sharing options...
