idosubaru Posted June 6, 2015 Share Posted June 6, 2015 looking into getting a press for Subaru wheel bearings, timing bearings, and bushings. Will the HF 12 ton variety work fine for that?http://www.harborfreight.com/12-ton-a-frame-industrial-heavy-duty-floor-shop-press-1667.html Link to comment Share on other sites More sharing options...
Fairtax4me Posted June 16, 2015 Share Posted June 16, 2015 For most things that will probably work fine. For really stuck wheel bearings it may not have enough oomph. Link to comment Share on other sites More sharing options...
jonbfish Posted October 29, 2016 Share Posted October 29, 2016 Any follow up on this? I was looking at a similar one at Northern Tools this morning for wheel bearings. Link to comment Share on other sites More sharing options...
idosubaru Posted October 30, 2016 Author Share Posted October 30, 2016 I haven't gotten one yet. Link to comment Share on other sites More sharing options...
matt167 Posted October 30, 2016 Share Posted October 30, 2016 The 20 ton goes on sale for not much more than that. I did opt for the 12 ton, but it's still in the boxes Link to comment Share on other sites More sharing options...
jonbfish Posted November 9, 2016 Share Posted November 9, 2016 Good call, saw a 20 ton at HF for $200. That should be enough for wheel bearings? And if the jack is junk I can always get a better one and still use the frame? Link to comment Share on other sites More sharing options...
czny Posted November 12, 2016 Share Posted November 12, 2016 Good call, saw a 20 ton at HF for $200. That should be enough for wheel bearings? And if the jack is junk I can always get a better one and still use the frame? If you wait for the discounts you could get that 20 ton for $160 & use the difference toward some nice press plates like from SWAG offroad: http://www.swagoffroad.com/ARBOR-PRESS-PLATES_p_7.html Those arbor plates supplied with HF presses just aren't what I would call safe at any speed. And for fabbing brackets & skid plates: http://www.swagoffroad.com/20-TON-Press-Brake-DIY-Builder-Kit_p_40.html Link to comment Share on other sites More sharing options...
jonbfish Posted November 15, 2016 Share Posted November 15, 2016 Good call, just printed off a coupon for $160, think I'll pull the trigger this week. Link to comment Share on other sites More sharing options...
Numbchux Posted November 15, 2016 Share Posted November 15, 2016 I thought mine was less than that, but it was the cheapest one at HF when I bought it, and I don't see one for less.... Mine is plenty, I've probably done a dozen subaru wheel bearings. Lots of bushings, as well as some bearings and such. I've had a couple things fight me, but I opted to apply heat before maxing out the equipment. 12 Tons is a lot! Link to comment Share on other sites More sharing options...
