jono Posted June 8, 2015 Share Posted June 8, 2015 (edited) I've come across a distributor. But it's the older "clip style" 4 wire. Would I be able to use it in my 88? It's a 22100 AA053 Glad you started using part numbers as well ! I reckon next post you will be telling people you have an EA82 spfi 88 GL wagon. The other option is the multipoint fuelie with a pair of injectors mounted each end on the twin tube inlet manifold atop twin intake port mpfi heads. Yours must look just like a single tube, single port manifold and head combo. I have always associated clip on disty caps with carby , and screw held down caps with mpfi, NA & turbo. I am assuming your spfi distributor is a screw down. Not seen a carby distributor work with efi, but the 4 wires looks hopeful - what's it look like under the cap ? Guys in here have a lot of experience, and a lot of time to help collectively, sounds like you are gonna get there .....am reading on ..... Edited June 8, 2015 by jono 1 Link to comment Share on other sites More sharing options...
TomRhere Posted June 9, 2015 Share Posted June 9, 2015 I did a Google search on the number that was posted. Got lot's of hits for the pick-up in the disty, and a link to a thread on here. This laptop won't do links/quotes, so I can't put the link in here. Irritating as all get out...... I thought the thread had some good info in it on the differences of the disty's and their wiring over the years. Link to comment Share on other sites More sharing options...
npatricelli Posted June 9, 2015 Author Share Posted June 9, 2015 I've that clip disty wired as you said Tom and when I put a plug directly off the ignition coil I get spark!!! Thanks for the help, now I've got to make sure my engine is timed correctly and the distributor installed and wiring to spark plugs correct before I try starting her. Is there a best place to start? I wanna be extra sure I get it right the first time. I've done it on a Ford 300 I6 but that's a totally different beast, this subie seems much more complicated to get timing marks correct Link to comment Share on other sites More sharing options...
Subasaurus Posted June 9, 2015 Share Posted June 9, 2015 (edited) one cam is upright (pointing up) and the other is pointing down (180degrees the other way), its been a while since ive done my timing belt, maybe someone else can give more details about it. but one thing is for sure, its pretty easy compared to other vehicles. Edited June 9, 2015 by Subasaurus Link to comment Share on other sites More sharing options...
TomRhere Posted June 9, 2015 Share Posted June 9, 2015 Go to you tube and do a search for "The art of Subaru Maintenance" by MilesFox. He has videos of timing belt installation, and how to properly set the distributor, plug wires, what have you. Good info there. Link to comment Share on other sites More sharing options...
npatricelli Posted June 10, 2015 Author Share Posted June 10, 2015 Ok I got it running! Thanks so much everyone! Are these motors normally noisey? It runs very steady but I can hear what sounds like the valves ticking but unusually loud it seems Link to comment Share on other sites More sharing options...
Subasaurus Posted June 10, 2015 Share Posted June 10, 2015 Ok I got it running! Thanks so much everyone! Are these motors normally noisey? It runs very steady but I can hear what sounds like the valves ticking but unusually loud it seemsDing, Ding, Ding we have a winner!!! Guess what time it is! its time to replace that Oil Pump! Link to comment Share on other sites More sharing options...
npatricelli Posted June 11, 2015 Author Share Posted June 11, 2015 Oh fantastic haha. I have to find out where it is and get crackin again. I appreciate everyone's help so much! By the time I'm done I'll be an expert at these EA82 engines Link to comment Share on other sites More sharing options...
npatricelli Posted June 11, 2015 Author Share Posted June 11, 2015 I can't seem to find an oil pump alone. I keep finding kits with new timing belts, there's brand new belts already on it Link to comment Share on other sites More sharing options...
npatricelli Posted June 11, 2015 Author Share Posted June 11, 2015 Scratch that it was a water pump with timing belts and all that. Anyone have an oil pump laying around? Link to comment Share on other sites More sharing options...
