Peter w Posted June 12, 2015 Share Posted June 12, 2015 Hi. I have a 1998 EJ25 250TB. Occasionally it doesn't start, sounds like it wants to but doesn't fire, it will eventually start if I let it sit for a bit longer, runs ok and doesn't to it all the time. I had a diagnostic fault code for cam angle sensor. Is this typical symptoms for a faulty cam angle sensor? Thanks. Link to comment Share on other sites More sharing options...
lmdew Posted June 12, 2015 Share Posted June 12, 2015 Usually they are either good or failed. Might check the wiring and plug. When it does not start are you getting fuel and no spark? Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted June 12, 2015 Share Posted June 12, 2015 I have read that cam angle fault will cause the ECU to cut fuel. 1 Link to comment Share on other sites More sharing options...
