jread Posted June 13, 2015 Share Posted June 13, 2015 I know this has been done about 1000 times but I can't seem to find any other specific relays other than the Bosch WR1 for the starter problem I'm having.I'm looking to add a starter or ignition relay to my 93 Loyale and just want to spend $10, I'd pony up $25 for the bosch kit but the issue is I need to pick it up from a store and not ship it as I'm visiting the states (from Canada) and moving around lots. Does anyone have a specific one that will work that's around $10?http://www.oreillyauto.com/site/c/detail/IDI0/250672/01748.oap?year=1993&make=Subaru&model=Loyale&vi=1270167&ck=Search_ignition+relay_1270167_3154&keyword=ignition+relayThis one is in my ballpark but has 6 posts instead of 4 I see most posting. Anyone have an idea how it works? Haven't been able to understand the diagrams I've seen. Quote Link to comment Share on other sites More sharing options...
jread Posted June 13, 2015 Author Share Posted June 13, 2015 This one is $5 will it work? Not sure if its rated high enough.http://www.oreillyauto.com/site/c/detail/BLZ0/DF005W/N0381.oap?ck=Search_N0381_1270167_3154&pt=N0381&ppt=C0335 Quote Link to comment Share on other sites More sharing options...
ihscout54 Posted June 13, 2015 Share Posted June 13, 2015 I suppose im unaware of the conversion your attempting, but that 30a lighting relay should be acceptable for engaging a starter solenoid. Another thought for you is Radioshack. Its been 5+ years since ive bought from them but they used to have the bosch 4/5 pin types in their bins 40a and even 60a and they were like 6-7 bux. I hear that radioshacks are no longer on every corner now, tho. Quote Link to comment Share on other sites More sharing options...
jread Posted June 13, 2015 Author Share Posted June 13, 2015 Basically the ignition switch wears out and makes it hard to start, because its old it doesn't have a relay so adding one in works perfectly. Quote Link to comment Share on other sites More sharing options...
ihscout54 Posted June 13, 2015 Share Posted June 13, 2015 I figured out why you were doing it. I was unaware if it being a common mod. From the tone of your post it has been well documented? If the contacts in the switch are pretty flakey it may not be reliable even to trigger a relay. If it works its cheaper than an ign switch and youll probably never have to worry about that part of the switch again. Check radioshack the quality of their relays was better than the cheapy parts stores. Good luck. Quote Link to comment Share on other sites More sharing options...
TOONGA Posted June 14, 2015 Share Posted June 14, 2015 This is a very common mod almost every "old" subaru could benefit with this being done. I did a search on google, as I didn't bookmark the page in my subaru bookmarks taken from http://www.ausubaru.com/forum/showthread.php?t=22702 http://www.ultimatesubaru.org/forum/topic/61722-weak-points-in-the-starter-circuit-good-jy-relay-info-for-retrofitting-within/ the USMB thread is actually in the Ausubaru one as well As for Relays you can source cheap relays from anywhere on ebay for around 10 - 20 Au dollars (way less in Us dollars) http://www.ebay.com/bhp/12v-relay-5-pin?_trksid=p2045573.m2388 as long as they are 4 or 5 post and 20-30 amps they will work. TOONGA Quote Link to comment Share on other sites More sharing options...
DaveT Posted June 14, 2015 Share Posted June 14, 2015 I've used the lighting relay that NAPA stocks. Something like 30 amps. Quote Link to comment Share on other sites More sharing options...
jread Posted June 14, 2015 Author Share Posted June 14, 2015 Sweet just going to buy a $5 30amp relay. Seems like a much better option than spending 25! Quote Link to comment Share on other sites More sharing options...
jread Posted June 14, 2015 Author Share Posted June 14, 2015 Also for any future readers who really don't get relays this helped me understand what the diagrams mean. http://www.autoshop101.com/forms/hweb2.pdf 1 Quote Link to comment Share on other sites More sharing options...
soopsoop Posted June 19, 2015 Share Posted June 19, 2015 you could get one at a wrecking yard for 3 bucks. Quote Link to comment Share on other sites More sharing options...
