palfer Posted June 14, 2015 Share Posted June 14, 2015 Hi All- Wipers work fine on all three settings (int, low and high) but when I pull the lever to me to activate the "mist" function---nothing. Not a big deal, especially considering how often it rains in the desert. I think I use it more to wipe dust than water.. Anyway, was wondering if there was a quick fix. thanks- Link to comment Share on other sites More sharing options...
Pgh_Scoob Posted June 14, 2015 Share Posted June 14, 2015 do you hear the pump running when you pull to mist? If not then most likely the pump being bad.. if you do hear it run then look for a disconnected hose under the hood or possibly clogged nozzles. Hope this helps Greg Link to comment Share on other sites More sharing options...
