taslazza Posted June 19, 2015 Share Posted June 19, 2015 Hi, New member here does any one know how to get the high beams to switch on a 92 GL wagon L series? I checked fuses, bulbs, grounds all ok. Could the problem be in the steering column switch ? Is there a easy way to check the relays? Thanks Taslazza Link to comment Share on other sites More sharing options...
Cougar Posted June 19, 2015 Share Posted June 19, 2015 Verify that voltage is getting to the highs when the switch position is selected. If you don't have power getting to them in that position then the light switch needs to be checked out along with the wiring to it. If you do have voltage there then the switched ground for the lights needs to be checked out. The ground for the lights is supplied through the switch. No need to check the relays as they are common to both lights. Link to comment Share on other sites More sharing options...
