90legl Posted June 20, 2015 Share Posted June 20, 2015 hi guys my name is trevor dean im from the united states i just picked up a 1990 legacy wagon l awd! im completely in love with it even for its age. but i want more. i know a version of the first generation legacy the legacy rs was a turbo model. i was wonder what the specific motor code to that motor is and a few other things 1. will my cross member be compatible with the new motor? 2. what the name of the turbo motor is i know i have the ej22 at the moment. 3 will my engine loom work with the the turbo ecu and turbo motor? 4. what else will i need beside the motor ecu and few other things to make it work. any help will be more than appreciated and i am mechanically inclined thank you all and hope to get this build on the road asap! Link to comment Share on other sites More sharing options...
Crawlerdan Posted June 21, 2015 Share Posted June 21, 2015 if you want a turbo engine- you will need to modify your xmember for an up pipe, or use a turbo member legacy turbos used the ej22t- it will bolt in fine, your ecu will probably run the turbo, but not safely, you will need a stand alone harness, or swap to a turbo set up you can use your trans and rear diff. but they will live on borrowed time if you boost them hard. shrapnel for the trophy case definitely Link to comment Share on other sites More sharing options...
