gar52hpny Posted June 24, 2015 Share Posted June 24, 2015 I WAS TOLD AFTER REMOVING THE NEGATIVE BATTERY TERMINAL TO CLEAR THE EMISSIONS COMPUTER YOU NEED TO DRIVE THE CAR A NUMBER OF MILES. CAN SOMEONE LET ME KNOW THE NUMBER OF MILES THAT I NEED TO DRIVE TO RESET THE EMISSIONS COMPUTER THAT WILL ALLOW THE NYS EMISSIONS INSPECTION TO BE COMPLETED SUCESSFULLY. THANK YOU, GARY Link to comment Share on other sites More sharing options...
destey Posted June 24, 2015 Share Posted June 24, 2015 Watching my obd2 scanner, not sure number of miles, but highway speeds make the CAT and O2 test go from INC to OK. Doesn't do it just driving around the city for a couple of minutes. Most of the other tests are quick. The longest one I think is the EVAP, and here's the conditions for the system to mark it complete: Quote When you are driving under a certain set of conditions (don't rememberthe exact specs, but it's something like 15-85% fuel, under 3000 RPM,steady speed under 75, higher than 45, and the car has been warm forover 8 minutes), the ECM starts a EVAP self test - it opens the PURGEsolenoid, which starts pulling a vacuum on the system, and closes theVENT solenoid, which seals of the system.It then monitors the fuel tank pressure sensor to see if:A. there is a drop in pressureB. the drop in pressure is heldIf either of those conditions fail on two consecutive drive cycles, you will get CEL and the associated code. Link to comment Share on other sites More sharing options...
AdventureSubaru Posted June 24, 2015 Share Posted June 24, 2015 Varies depending on how you are driving. 20-30 miles of highway has been good for mine. Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted June 24, 2015 Share Posted June 24, 2015 different monitors complete with different circumstances. i think some need a certain number of cold starts? and some States will allow 1 or 2 monitors to be incomplete, perhaps depending on which ones. I'd suspect most folks would be OK after 3 days or so of driving. Link to comment Share on other sites More sharing options...
Fairtax4me Posted June 24, 2015 Share Posted June 24, 2015 Subaru TSB with the manufacturer recommended procedure to set all I/M Monitors. http://techinfo.subaru.com/proxy/65245/pdf/065245-11-72-0458832.pdf Link to comment Share on other sites More sharing options...
