INSPECTION EMISSIONS TEST-2002 OUTBACK 4 CYLINDER
I WAS TOLD AFTER REMOVING THE NEGATIVE BATTERY TERMINAL TO CLEAR THE EMISSIONS COMPUTER YOU NEED TO DRIVE THE CAR A NUMBER OF MILES. CAN SOMEONE LET ME KNOW THE NUMBER OF MILES THAT I NEED TO DRIVE TO RESET THE EMISSIONS COMPUTER THAT WILL ALLOW THE NYS EMISSIONS INSPECTION TO BE COMPLETED SUCESSFULLY.
THANK YOU,
GARY
Watching my obd2 scanner, not sure number of miles, but highway speeds make the CAT and O2 test go from INC to OK. Doesn't do it just driving around the city for a couple of minutes. Most of the other tests are quick. The longest one I think is the EVAP, and here's the conditions for the system to mark it complete:
When you are driving under a certain set of conditions (don't remember
the exact specs, but it's something like 15-85% fuel, under 3000 RPM,
steady speed under 75, higher than 45, and the car has been warm for
over 8 minutes), the ECM starts a EVAP self test - it opens the PURGE
solenoid, which starts pulling a vacuum on the system, and closes the
VENT solenoid, which seals of the system.
It then monitors the fuel tank pressure sensor to see if:
A. there is a drop in pressure
B. the drop in pressure is held
If either of those conditions fail on two consecutive drive cycles, you will get CEL and the associated code.
different monitors complete with different circumstances. i think some need a certain number of cold starts?
and some States will allow 1 or 2 monitors to be incomplete, perhaps depending on which ones.
I'd suspect most folks would be OK after 3 days or so of driving.
