Baslyn Posted June 25, 2015 Share Posted June 25, 2015 Hi, I have a 2000 Legacy L Station. I just bought it this past January. For some reason about a month ago as I was driving down the Highway doing about 75 mph up a mountain, I noticed that the Temp gauge started to climb and stop just before it got into the red zone. Turning the heater on brought the temp back down to normal. On the other side of the mountain I didn't have any problems with the temp gauge rising again. Until about a week ago.... Now when I'm running at any speeds past 65 the temp guage will climb. But the moment that I slow down to 65 or under then temp starts to go back to normal. Both fans do come on. And I have noticed that when I come to a stop sometimes that the car sounds/feels like it's bubbling but when I look into the overflow tank there are no bubbles coming out of the hose. Link to comment Share on other sites More sharing options...
nipper Posted June 25, 2015 Share Posted June 25, 2015 Three things to look at (for now we will skip the ever fearful headgasket) 1- Radiator cap 2-Thermostat 3- Cooling system leak How is your coolant level? Link to comment Share on other sites More sharing options...
Baslyn Posted June 25, 2015 Author Share Posted June 25, 2015 On 6/25/2015 at 3:46 AM, nipper said: Three things to look at (for now we will skip the ever fearful headgasket) 1- Radiator cap 2-Thermostat 3- Cooling system leak How is your coolant level? Coolant level is full. Overflow tank is at the fill line mark. Link to comment Share on other sites More sharing options...
Fairtax4me Posted June 25, 2015 Share Posted June 25, 2015 (edited) But, Is the radiator full? Another C-villian! We're multiplying on here... Edited June 25, 2015 by Fairtax4me Link to comment Share on other sites More sharing options...
nipper Posted June 25, 2015 Share Posted June 25, 2015 If the cap is bad it wont draw coolant back int the radiator. It chouldnt be full, should be at the hot or cold line. Link to comment Share on other sites More sharing options...
Baslyn Posted June 25, 2015 Author Share Posted June 25, 2015 On 6/25/2015 at 5:16 AM, Fairtax4me said: But, Is the radiator full? Another C-villian! We're multiplying on here... Yes the radiator is full On 6/25/2015 at 5:24 AM, nipper said: If the cap is bad it wont draw coolant back int the radiator. It chouldnt be full, should be at the hot or cold line. And it's in between the hot and cold lines in the reserve tank Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted June 25, 2015 Share Posted June 25, 2015 try cleaning the dead bees out of the radiator ,some people have had a lot of debris collect between the a/c cond. and rad. have the radiator flow tested? Link to comment Share on other sites More sharing options...
Fairtax4me Posted June 25, 2015 Share Posted June 25, 2015 Try checking for leaves/dirt/dust/dead bugs stuck to the front of the radiator and condenser, as Texan suggested. Beyond that, I would suspect a faulty thermostat or partially clogged radiator. 1 Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted June 25, 2015 Share Posted June 25, 2015 yeah, could be a non-oem style t'stat in there now, or a bad t'stat. if you replace it, get OEM (or the oem Stant) Link to comment Share on other sites More sharing options...
Baslyn Posted June 25, 2015 Author Share Posted June 25, 2015 Ok just finished putting on a new Thermostat (from dealership), and Radiator cap (from dealership). Also while I had the car up changed the oil. I'm about to go on a drive and will post the results. Link to comment Share on other sites More sharing options...
Baslyn Posted June 25, 2015 Author Share Posted June 25, 2015 On 6/25/2015 at 2:36 PM, 1 Lucky Texan said: yeah, could be a non-oem style t'stat in there now, or a bad t'stat. if you replace it, get OEM (or the oem Stant) No it was definitely an OEM tstat. Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted June 25, 2015 Share Posted June 25, 2015 (edited) dang - hoping it isn't HGs. if it overheats again, pull over and, with the engine running, see if either; 1. there are bubbles coming up thru the coolant in the overflow tank or 2. the overflow bottle is filled vey high or spilling over. (don't remove the rad cap on a hot engine!) Edited June 25, 2015 by 1 Lucky Texan Link to comment Share on other sites More sharing options...
Baslyn Posted June 25, 2015 Author Share Posted June 25, 2015 (edited) Well it's still an issue. Was driving on highway doing 75 mph with ac on and it took longer for it to happen but the temp went up to just before red. slowed down to about 60 and temp dropped. No bubbling sound with the new tstat in Edited June 25, 2015 by Baslyn Link to comment Share on other sites More sharing options...
desertsubaru Posted June 25, 2015 Share Posted June 25, 2015 On 6/25/2015 at 11:27 PM, Baslyn said: Well it's still an issue. Was driving on highway doing 75 mph with ac on and it took longer for it to happen but the temp went up to just before red. slowed down to about 60 and temp dropped. No bubbling sound with the new tstat in I had the same thing happen with an EA82 wagon. It turned out that the radiator was internally blocked. Try a Radiator flush first before replacing the Rad. Link to comment Share on other sites More sharing options...
Rooster2 Posted June 26, 2015 Share Posted June 26, 2015 On 6/25/2015 at 11:52 PM, desertsubaru said: I had the same thing happen with an EA82 wagon. It turned out that the radiator was internally blocked. Try a Radiator flush first before replacing the Rad. Thinking same thing....the radiator is plugged up. Does the car's heater work really well...as in pumping out really hot air. If not, then it is possible that the previous owner dumped a bunch of radiator stop leak in the system. Result can be blocked radiator, and blocked heater rad unit. Previous owner may have had a head gasket leak, so dumped something in the cooling system to see if that would help. Things to think about. Link to comment Share on other sites More sharing options...
keith3267 Posted June 26, 2015 Share Posted June 26, 2015 Usually these symptoms are due to a system not holding pressure and the most common cause for not holding pressure is the radiator cap. Check the area inside the radiator where the inner gasket of the radiator cap seals to make sure there are no gaps or deformities. Check the rubber on the new cap to make sure it didn't come with a defect. A new cap should have fixed the issue. Maybe you still have a bubble in there. Link to comment Share on other sites More sharing options...
Fairtax4me Posted June 26, 2015 Share Posted June 26, 2015 Do you have an infrared thermometer? You can use that to check the radiator for "cold" spots. Its kind of tricky to do on these since the fans are in the way. You drive the car until it gets to normal temp, then check the radiator in several places for temperature variation in the core. Temperature should have a steady decrease from left-right or top-bottom depending on which way the core tubes run. (Horizontal or vertical) If you find a spot in the core where the temp drops drastically that indicates a clog in the core tubes in that area. Link to comment Share on other sites More sharing options...
lstevens76 Posted June 27, 2015 Share Posted June 27, 2015 I'm actually suprised no one said to simply get an infrared thermometer and check the temp of the system in general. Have you had any other symptoms besides the gauge? It could be that your problem is actually in the temperature sender for the gauge (not sure if that's on the Coolant Temp Sensor or separate on that car). Link to comment Share on other sites More sharing options...
desertsubaru Posted June 27, 2015 Share Posted June 27, 2015 On 6/27/2015 at 1:22 PM, lstevens76 said: I'm actually suprised no one said to simply get an infrared thermometer and check the temp of the system in general. Have you had any other symptoms besides the gauge? It could be that your problem is actually in the temperature sender for the gauge (not sure if that's on the Coolant Temp Sensor or separate on that car). Read the post above yours.#17 Link to comment Share on other sites More sharing options...
lstevens76 Posted June 27, 2015 Share Posted June 27, 2015 On 6/27/2015 at 1:30 PM, desertsubaru said: Read the post above yours.#17 Fairtax was referring to using it to specifically check the radiator for cold spots to identified a potentially clogged radiator. What I was referring to is verifying the gauge is actually reporting correctly. It's always a possibility the problem could be the temp sender unit or the gauge itself and the car isn't overheating at all. I've only seen that once myself (not on a Subaru) and don't think it's very common, but it's always a possibility. Link to comment Share on other sites More sharing options...
Fairtax4me Posted June 27, 2015 Share Posted June 27, 2015 On 6/27/2015 at 1:22 PM, lstevens76 said: I'm actually suprised no one said to simply get an infrared thermometer and check the temp of the system in general. Have you had any other symptoms besides the gauge? It could be that your problem is actually in the temperature sender for the gauge (not sure if that's on the Coolant Temp Sensor or separate on that car). Guage and computer use the same sender on this year. Symptoms don't sound like a bad temp sender. That would show up anytime. The OPs problem only happens on the highway. Link to comment Share on other sites More sharing options...
Baslyn Posted June 28, 2015 Author Share Posted June 28, 2015 On 6/26/2015 at 12:17 AM, Rooster2 said: Thinking same thing....the radiator is plugged up. Does the car's heater work really well...as in pumping out really hot air. If not, then it is possible that the previous owner dumped a bunch of radiator stop leak in the system. Result can be blocked radiator, and blocked heater rad unit. Previous owner may have had a head gasket leak, so dumped something in the cooling system to see if that would help. Things to think about. Link to comment Share on other sites More sharing options...
Baslyn Posted June 28, 2015 Author Share Posted June 28, 2015 (edited) Yes the heater blows hot like no other car I've ever owned. Also have had no fluid loss. Checked tonight before leaving work. Doesn't look like any damage to new rad cap. Edited June 28, 2015 by Baslyn Link to comment Share on other sites More sharing options...
Baslyn Posted June 28, 2015 Author Share Posted June 28, 2015 Also don't know if this is the same problem but for some reason the front passenger side plug wire keeps coming off the plug. Getting a knock sensor code when it comes off. Plug it back in, clear the code and it stays gone until it pops off again. I just changed all plugs and wires about a month ago. Link to comment Share on other sites More sharing options...
Fairtax4me Posted June 28, 2015 Share Posted June 28, 2015 Rockauto.com has good prices on radiators. They have a Denso for $105 (high quality OE manufacturer for most Japanese brands) Cheaper aftermarket brands for about $70. Link to comment Share on other sites More sharing options...
