mcgarvey2001 Posted June 26, 2015 Share Posted June 26, 2015 (edited) In making my wheel/tire selection I considered the clearance for coilovers, wheel well and brakes but completely blew off the trailing arm. I have 7" wide (6" rim width, 54mm offset) 15" rims and was going to mount 225/75s but this well clearly rub the outer arm (xt6 suspension). It looks like it would need to be spaced out almost an inch just to get to zero clearance. What's my best option here? I'd really like to run these tires. Is there a good low offset rim choice? Edited June 26, 2015 by mcgarvey2001 Link to comment Share on other sites More sharing options...
mcgarvey2001 Posted June 26, 2015 Author Share Posted June 26, 2015 I'm not really excited about wheel spaced, but does anyone have a recommendation for those? Link to comment Share on other sites More sharing options...
djellum Posted June 27, 2015 Share Posted June 27, 2015 id contact SJR. he does wheel adaptors and such for changing bolt patterns, so he could probably give you good advise on how to safely space. may also make you a set of spacers. 1 Link to comment Share on other sites More sharing options...
