nitpikker247 Posted June 29, 2015 Share Posted June 29, 2015 I have just replaced my REAR disc brakes. (Rotors, Calipers and Pads) Passenger side is OK! Drivers' side, however... The outer 1/3 of the New rotor is not being contacted by the New Pads. I figured I would switch the pads with the other side, being there was only a few hundred miles driven. No Change.Then I made sure the Slide Pins were moving Freely.They were. Figured it was a Defective Rotor. Exchanged it. No change. Then I figured it must be a defective Caliper. So I exchanged that! STILL, NO CHANGE!! When you look at the Rotor, The Inner 2/3 of Is wearing properly. The outer 1/3 still shows the Brand New Machined Surface with some Oxidation. No Wear. A N Y S U G G E S T I O N S ? ! Exasperated Link to comment Share on other sites More sharing options...
Olnick Posted June 29, 2015 Share Posted June 29, 2015 Welcome to the USMB, nitpicker. If you post your questions on the New Gen forum you'll have a better chance of getting helpful responses. 1 Link to comment Share on other sites More sharing options...
nitpikker247 Posted June 30, 2015 Author Share Posted June 30, 2015 Thanks, Much Appreciated! Link to comment Share on other sites More sharing options...
